Boost your enterprise's productivity with the NVIDIA® NVS™ 310 dual-display professional graphics solution. This graphics board provides a reliable hardware and software platform to enable fast, cost-effective integration, deployment, and support across large enterprises. Each NVS 310 board features DisplayPort 1.2, NVIDIA Mosaic™ Technology, and NVIDIA NVIEW desktop management software, and can drive up to two 30-bit displays at resolutions up to 2560x1600 at 60Hz. This allows business professionals to maximize productivity by increasing their desktop real estate and leveraging advanced application-management tools. Plus, every NVS 310 is tested on leading business applications and designed with the ideal balance of performance and power to meet the needs of today's most demanding business user.
NVIDIA power management technology reduces overall system energy costs. It intelligently adapts the total power utilization of the graphics subsystem based on the applications being run by the end user. This power optimized design helps reduce Total Cost of Ownership (TCO) and increase reliability. PNY provides unsurpassed service and commitment to its professional graphics customers offering: 3-Year Warranty, pre and post-sales support, dedicated NVS Field Application Engineers and direct tech support hotlines. In addition, PNY delivers a complete solution including the appropriate adapters, cables, brackets, Software installation disc and documentation to ensure a quick and successful install.
Fast DDR3 graphics memory
It is delivers high throughput to simultaneously play stunning HD video on each connected display. -
Intelligent Power Management
NVIDIA Power Management technology reduces overall system energy costs. It intelligently adapts the total power utilization of the graphics subsystem based on the applications being run by the end user. This power optimized design helps reduce Total Cost of Ownership (TCO) and increase reliability. -
NVIDIA CUDA
NVIDIA CUDA provides a development environment t and tool suite that unleash capabilities to solve various visualization challenges. -
Low-profile and flexible form factor
Simplifies IT administration and deployment throughout an enterprise. Regardless of desktop system or the display type NVS 310 has the ability to fit into any existing installations without being disruptive. -
Ultra-quiet fansink
Whisper-quiet 22 dba idle, 22.4 dba maximum at room temperature. -
Dual DisplayPort connectors
Supports ultra-high resolution panels up to 2560 x 1600 at 30 bpp - enabling maximum range, resolution, refresh rate, and color depth designed to support the display technologies. DisplayPort 1.2 multi-streaming allows daisy chaining of compatible display or attachment via DisplayPort 1.2 compliant hubs. -
NVIDIA high definition video technology
NVIDIA high definition video technology is the combination of high-definition video processors that delivers unprecedented picture clarity, smooth video, accurate color, and precise image scaling for SD and HD video content. Features include, high-quality scaling, spatial temporal de-interlacing and high quality HD video playback - with low CPU utilization and power consumption. -
Multi-display experience with NVIDIA Mosaic technology
Mosaic technology enables seamless taskbar spanning as well as transparent scaling of any application across up to 8 displays.
- NVIDIA NVS 310 by PNY - graphics card - NVS 310 - 1 GB
- Graphics card - low profile
- Bus Type
- PCI Express 2.0 x16
- Graphics Engine
- NVIDIA NVS 310
- Memory
- 1 GB DDR3
- CUDA Cores
- 48
- Memory Interface
- 64-bit
- Max Resolution
- 2560 x 1600
- Max Monitors Supported
- 2
- 2 x DisplayPort
- API Supported
- DirectX 11, OpenCL, DirectCompute, OpenGL 4.1, OpenACC
- 14.5 cm x 6.9 cm
- Environmental Standards
- ENERGY STAR Qualified
- 3-year warranty
- Bus Type
- Graphics Engine
- NVIDIA NVS 310
- CUDA Cores
- 48
- Max Resolution
- 2560 x 1600 at 60 Hz
- 2
- 2 x DisplayPort
- API Supported
- Nvidia nVIEW Multi-Display Technology, Nvidia CUDA technology, Nvidia GigaThread technology, Nvidia 3D Vision technology, Nvidia Scalable Geometry Engine, NVIDIA Mosaic, Shader Model 5.0, Dolby Digital Plus, Nvidia 3D Vision Pro, Dual-stream Hardware Acceleration, GPU Tessellation, Multi-Stream Technology, linear pulse-code modulation (LPCM) support, HDCP
- Size
- 1 GB
- Technology
- DDR3 SDRAM
- Bus Width
- 64-bit
- Bandwidth
- 14 GBps
- OS Required
- Linux, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Oracle Solaris, Windows 8 (32/64 bits), Windows 8.1 (32/64 bits), Windows 10 (32/64 bits)
- 19.5 Watt
- Included Accessories
- Low-profile bracket
- Software Included
- Display drivers, Nvidia nView Desktop Management Software
- 14.5 cm
- 6.9 cm
- ENERGY STAR Certified
- Limited warranty - 3 years
C2G 3m DisplayPort Cable with Latches M/M - Black | In Stock | £12.92 |
