Fast 1GB DDR3 graphics memory
Delivers high throughput to simultaneously play stunning HD video on each connected display.
Intelligent Power Management
NVIDIA Power Management technology reduces overall system energy costs. It intelligently adapts the total power utilization of the graphics subsystem based on the applications being run by the end user. This power optimized design helps reduce Total Cost of Ownership (TCO) and increase reliability.
NVIDIA CUDA
48 CUDA GPU parallel computing cores compatible with all CUDA accelerated applications. NVIDIA CUDA provides a development environment and tool suite that unleashes new capabilities to solve various visualization challenges.
Low-Profile and Flexible Form Factor
Simplifies IT administration and deployment throughout an enterprise. Regardless of desktop system (standard tower PC. workstation, small form factor system) or the display type (LCD, DLP, plasma) NVS 310 has the ability to fit into any existing installations without being disruptive.
Ultra-Quiet Fansink
Whisper-quiet 22 dba idle, 22.4 dba maximum at room temperature
Dual DisplayPort 1.2 Connectors
Supports ultra-high resolution panels up to 2560 x 1600 at 30bpp - enabling maximum range, resolution, refresh rate, and color depth designed to support the latest display technologies. DisplayPort 1.2 multi-streaming allows daisy chaining of compatible displays or attachment via DisplayPort 1.2 compliant hubs.
DVI-D Single-Link Connectors
Two NVIDIA NVS certified high-quality DisplayPort to DVI-D single-link adapters allow DVI displays to be driven at resolutions up to 1920 x 1200 at 60Hz.
NVIDIA High Definition Video Technology
NVIDIA high definition video technology is the combination of high-definition video processors and software that delivers unprecedented picture clarity, smooth video, accurate color, and precise image scaling for SD and HD video content. Features include, high-quality scaling, spatial temporal de-interlacing, inverse telecine and high quality HD video playback - with low CPU utilization and power consumption.
NVIEW Advanced Desktop Software
The NVIEW Advanced Desktop Software delivers maximum flexibility for single-large display or multi-display options, providing unprecedented end-user control of the desktop experience for increased productivity.
Multi-Display Experience with NVIDIA Mosaic
NVIDIA Mosaic enables seamless taskbar spanning as well as transparent scaling of any application across up to 8 displays. Works over multiple displays or one ultra-high resolution display using a single or multiple NVS graphics cards (Windows 8 and 7 only).
Unified Driver Architecture (UDA)
Part of the NVIDIA Forceware unified software environment (USE). The NVIDIA UDA guarantees forward and backward compatibility with software drivers. Simplifies upgrading to a new NVIDIA product because the latest driver supports all current NVIDIA products.
Compatible with Industry Leading Applications
Extensive compatibility testing ensures that NVS 310 provides a stable and reliable graphics platform for industry leading business applications including Microsoft Office, Adobe Acrobat, Lotus Notes, OpenText Exceed and Exceed onDemand, TradeStation, Reuters Financial Software, pcAnywhere, Internet Explorer 9, Firefox 4, and many other essential business and enterprise applications.
Fast DDR3 graphics memory
It is delivers high throughput to simultaneously play stunning HD video on each connected display. -
NVIDIA Power Management technology reduces overall system energy costs. It intelligently adapts the total power utilization of the graphics subsystem based on the applications being run by the end user. This power optimized design helps reduce Total Cost of Ownership (TCO) and increase reliability. -
NVIDIA CUDA
NVIDIA CUDA provides a development environment t and tool suite that unleash capabilities to solve various visualization challenges. -
Low-profile and flexible form factor
Simplifies IT administration and deployment throughout an enterprise. Regardless of desktop system or the display type NVS 310 has the ability to fit into any existing installations without being disruptive. -
Ultra-quiet fansink
Whisper-quiet 22 dba idle, 22.4 dba maximum at room temperature. -
Dual DisplayPort connectors
Supports ultra-high resolution panels up to 2560 x 1600 at 30 bpp - enabling maximum range, resolution, refresh rate, and color depth designed to support the display technologies. DisplayPort 1.2 multi-streaming allows daisy chaining of compatible display or attachment via DisplayPort 1.2 compliant hubs. -
NVIDIA high definition video technology is the combination of high-definition video processors that delivers unprecedented picture clarity, smooth video, accurate color, and precise image scaling for SD and HD video content. Features include, high-quality scaling, spatial temporal de-interlacing and high quality HD video playback - with low CPU utilization and power consumption. -
Multi-display experience with NVIDIA Mosaic technology
Mosaic technology enables seamless taskbar spanning as well as transparent scaling of any application across up to 8 displays.
- NVIDIA NVS 310 by PNY - graphics card - NVS 310 - 1 GB
- Graphics card - low profile
- Bus Type
- PCI Express 2.0 x16
- Graphics Engine
- NVIDIA NVS 310
- Memory
- 1 GB DDR3
- CUDA Cores
- 48
- Memory Interface
- 64-bit
- Max Resolution
- 2560 x 1600
- Max Monitors Supported
- 2
- 2 x DisplayPort , 2 x DVI-D (Single-Link) - with adapter
- API Supported
- DirectX 11, OpenCL, DirectCompute, OpenGL 4.1, OpenACC
- 14.5 cm x 6.9 cm
- Environmental Standards
- ENERGY STAR Qualified
- 3-year warranty
- Bus Type
- Graphics Engine
- NVIDIA NVS 310
- CUDA Cores
- 48
- Max Resolution
- 2560 x 1600 at 60 Hz
- 2
- API Supported
- Nvidia nVIEW Multi-Display Technology, Nvidia CUDA technology, Nvidia GigaThread technology, Nvidia 3D Vision technology, Nvidia Scalable Geometry Engine, NVIDIA Mosaic, Shader Model 5.0, Dolby Digital Plus, Nvidia 3D Vision Pro, Dual-stream Hardware Acceleration, GPU Tessellation, Multi-Stream Technology, linear pulse-code modulation (LPCM) support, HDCP
- Size
- 1 GB
- Technology
- DDR3 SDRAM
- Bus Width
- 64-bit
- Bandwidth
- 14 GBps
- OS Required
- Linux, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Oracle Solaris, Windows 8 (32/64 bits), Windows 8.1 (32/64 bits), Windows 10 (32/64 bits)
- 19.5 Watt
- Included Accessories
- Low-profile bracket
- Cables Included
- 2 x DisplayPort-DVI adapter
- Software Included
- Display drivers, Nvidia nView Desktop Management Software
- 14.5 cm
- 6.9 cm
- ENERGY STAR Certified
- Limited warranty - 3 years
C2G 3m DisplayPort Cable with Latches M/M - Black | In Stock | £12.92 |
