PNY NVIDIA Quadro M6000 12GB GDDR5 PCI-E 3.0x16 Graphics
Quicklinx: B66PWS00 Mfr#: VCQM6000-PB
Get real interactive expression with NVIDIA Quadro - the world's most powerful workstation graphics. The NVIDIA Quadro M6000, accelerated by NVIDIA's Maxwell GPU architecture, lets you conquer your most challenging visualization workloads with ease and enjoy interactive physically based rendering of your work. 12 GB of GDDR5 GPU memory with ultra-fast bandwidth allows you to create and render large, complex models and compute massive datasets. Plus, there's the all-new display engine that drives up to four 4K resolution displays natively with DisplayPort 1.2 support for ultra-high resolutions like 4096 x 2160 at 60 Hz with 30-bit color. Synchronize multiple displays across systems with the Quadro Sync board (see PNY PN VCQM6000SYNC-PB) and accelerate data transfer with external I/O boards through GPU Direct for Video and dual-copy engines.
Designed and built specifically for professional workstations, NVIDIA Quadro GPUs power more than 200 professional applications across a broad range of industries including manufacturing, media and entertainment, sciences, and energy. Professionals trust them to realize their most ambitious visions - whether its product design, visualization and simulation, or spectacular visual storytelling - and get results to market faster.
PNY provides unsurpassed service and commitment to its professional graphics customers offering: pre and post-sales support, dedicated Quadro Field Application engineers and direct tech support hot lines. In addition, PNY delivers a complete solution including the appropriate adapters, cables, brackets, software installation disc and documentation to ensure a quick and successful install.
See Resource tab for the full data sheet
  • Accelerate your entire workflow
    The NVIDIA Quadro M6000 professional graphics solution is a true technological breakthrough, delivering faster performance across a broad range of design, animation and video applications. Built on the NVIDIA Fermi architecture, the Quadro M6000 is the professional-class GPU to integrate high performance computing capabilities with advanced visualization techniques, transforming modern workflows. Featuring Scalable Geometry Engine technology, Quadro can deliver an unheard of 1.3 billion triangles per second, shattering previous 3D graphics limitations.
  • Incredible Quadro GPU architecture
    Modern applications harness NVIDIA CUDA parallel processing architecture of the Quadro M6000 solution to deliver performance gains faster when running computationally intensive applications such as ray tracing, video processing and computational fluid dynamics. For high-precision, data-sensitive applications, Quadro M6000 is the only professional graphics solution with ECC memory and fast double precision capabilities to ensure the accuracy and fidelity of your results. From medical imaging to structural analysis applications, data integrity and precision is assured, without sacrificing performance.
  • Visual supercomputing platform
    Quadro M6000 is not only a graphics processor; it drives an entire visual supercomputing platform, incorporating hardware and software that enables advanced capabilities
NVIDIA Quadro M6000 - graphics card - Quadro M6000 - 12 GB
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
NVIDIA Quadro M6000
12 GB GDDR5
CUDA Cores
3072
RAMDAC
400 MHz
Memory Interface
384-bit
Max Resolution
4096 x 2160
Max Resolution Details
DVI: 2560 x 1600 at 60 Hz / DisplayPort: 4096 x 2160 at 50 Hz / VGA: 2048 x 1536 at 85 Hz
Max Monitors Supported
4
DVI-I (dual link) , 4 x DisplayPort , 3 x DVI-D (Single-Link) - with adapter , VGA - with adapter
API Supported
OpenCL, DirectCompute 5.0, DirectX 12, OpenGL 4.5
26.7 cm x 11.2 cm
Environmental Standards
ENERGY STAR Qualified
3-year warranty
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
NVIDIA Quadro M6000
CUDA Cores
3072
RAMDAC
400 MHz
Max Resolution
4
API Supported
Dual Slot Fan Cooler, Nvidia nVIEW Multi-Display Technology, Nvidia CUDA technology, Nvidia GigaThread technology, Nvidia 3D Vision technology, Error Correcting Codes (ECC) Memory, Nvidia Scalable Geometry Engine, NVIDIA Parallel DataCache, NVIDIA Mosaic, Hardware Video Decode Acceleration, Shader Model 5.0, Dolby Digital Plus, Nvidia 3D Vision Pro, GPU Tessellation, NVIDIA GPU Boost, Nvidia Fast Approximate Antialiasing Technology (FXAA), OpenGL Quad Buffered Stereo Support, Dynamic Parallelism, Hyper-Q, Nvidia SMX Engine, Nvidia Quadro Mosaic Technology, Nvidia GPUDirect, Full 30-bit Display Pipeline, Nvidia Quadro Warp/Blend, Nvidia Temporal Anti-Aliasing Technology (TXAA), Maxwell architecture, ultra-quiet active fansink, HDCP
Size
12 GB
GDDR5 SDRAM
Bus Width
384-bit
Bandwidth
317 GBps
Linux, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Windows 8 (32/64 bits), Windows 8.1 (32/64 bits)
250 Watt
Stereo connector bracket, Dual 6-pin PCIe to 8-pin power cable
1 x DVI-VGA adapter , 3 x DisplayPort-DVI adapter
Software Included
Drivers & Utilities
26.7 cm
11.2 cm
ENERGY STAR Certified
Limited warranty - 3 years
Resources
The following resources are available for the PNY NVIDIA Quadro M6000 12GB GDDR5 PCI-E 3.0x16 Graphics
