PNY NVIDIA Quadro M5000 Sync 8GB GDDR5 PCI-E 3.0 X16 DVI
Quicklinx: BWFRWS00 Mfr#: VCQM5000SYNC-PB
Get real interactive expression with NVIDIA Quadro - the world's most powerful workstation graphics. NVIDIA's advanced Maxwell GPU architecture delivers incredible performance to let you unleash your creativity and conquer extreme workloads with ease. 8 GB of ultra-fast memory with ECC lets you create and render large, complex models and compute massive datasets, all with ECC support for added reliability. A display engine drives up to four 4K resolutions displays natively (4096 x 2160 at 60 Hz with 30-bit color).
Pair up two or more outputs to drive displays greater than 4K, and take advantage of NVIDIA Quadro Sync support to frame-lock multiple displays together (see PNY PN VCQM5000SYNC-PB), or use external I/O boards and NVIDIA's GPUDirect for Video to integrate the Quadro M5000 into broadcast, video or film production workflows.
Designed and built specifically for professional workstations, NVIDIA Quadro GPUs power more than 200 professional applications across a broad range of industries including manufacturing, media and entertainment, sciences, and energy. Professionals trust them to realize their most ambitious visions - whether its product design, visualization and simulation, or spectacular visual storytelling - and get results to market faster.
  • Maxwell streaming multiprocessor
    The heart of Maxwell' power efficient performance is its Streaming Multiprocessor which delivers incredible performance and unmatched power efficiency, through an improved instruction scheduler and new data path organization.
  • Maxwell memory architecture
    Improved caching effectiveness and significant enhancements in memory compression techniques in Maxwell reduces traffic and provides higher performance for applications dependent on memory bandwidth. Additionally, Maxwell's dedicated shared memory per SM (separated from the L1 cache) and larger L2 cache, dramatically improves programmability and efficiency.
  • Viewport multicast
    Dedicated hardware to automatically broadcast input geometry to render to multiple render targets which drastically speeds up 'multi projection(the ability of rendering the same scene from multiple view) leading to accelerated rendering for cube maps used in multi view projectors and 3D CAVE environments.
  • Sparse textures
    Virtualizes texture sizes enabling applications to seamlessly work with large and complex data sets regardless of the available frame buffer.
  • Accelerated voxelization
    Enhancements to voxel handling techniques enables fast voxelization which significantly accelerates workflows like fluid simulation and 3D printing.
  • Multiple copy engines
    Enables the highest rates of parallel data processing and concurrent throughput between the GPU and host, accelerating techniques such as ray tracing, color grading and physical simulation.
  • Bindless graphics
    Optimizes GPU utilization by dramatically reducing CPU-GPU interactions, enabling developers to implement more sophisticated and complex algorithms providing end users greater performance and higher levels of visual fidelity.
  • H.264 and HEVC encoder
    Dedicated H.264 and HEVC encode engine that is independent of 3D/compute pipeline and delivers faster than real-time performance for transcoding, video editing, and other encoding applications.
  • NVIDIA CUDA architecture
    Parallel-computing architecture that tightly integrates advanced visualization and compute features to significantly accelerate professional workflows.
  • NVIDIA scalable geometry engine
    Dramatically improves geometry performance across a broad range of CAD, DCC and medical applications, enabling you to work interactively with models and scenes that are an order of magnitude more complex than ever before.
  • Dynamic parallelism
    Simplifies GPU programming by allowing programmers to easily accelerate all parallel nested loops - resulting in a GPU dynamically spawning new threads on its own without going back to the CPU.
  • Large framebuffers with ultra-fast bandwidth
    Large GPU memory with fast bandwidth for display of complex models and scenes, as well as computation of large datasets.
  • PCI Express 3.0 compliance
    Supports data transfer rate up to 8 GT/sec per lane for an aggregate bandwidth of 32 GB/sec bi-directional (16 GB/sec in each direction.)
  • Error Correcting Code (ECC) on graphics memory
    Meets strict requirements for mission critical applications with uncompromised computing accuracy and reliability for workstations. Offers enhanced application data integrity protection through single bit memory error correction.
  • Ultra-quiet design
    Silent cooling design enables lower acoustics for an ultra-quiet desktop environment.
  • NVIDIA GPU boost
    Maximum application performance through automatic adjustment of the GPU clock to take maximum advantage of the power and thermal headroom of the card in real-time.
  • Full-Scene Antialiasing (FSAA)
    Up to 64X FSAA for dramatically reducing visual aliasing artifacts or "jaggies," resulting in unparalled image quality and highly realistic scenes.
  • NVIDIA FXAA and TXAA
    Reduces visible aliasing and delivers higher image quality without the performance hit by harnessing the power of the GPU's CUDA cores and film-style AA techniques.
  • GPU tessellation
    Quadro Tessellation Engines automatically generate finely detailed geometry for cinematic quality environments and scenes, without sacrificing performance.
  • 16K texture and render processing
    Provides the ability to texture from and render to 16K x 16K surfaces. Beneficial for applications that demand the highest resolution and quality image processing.
  • NVIDIA Quadro Mosaic technology
    Enables transparent scaling of the desktop and applications across up to 16 displays from 4 GPUs from a single workstation while delivering full performance and image quality.
  • Multi-display support
    Display engine drives up to four displays simultaneously and fully supports the next generation Display Port 1.2 standard capable of resolutions such as 3840 x 2160 at 60Hz, making it easy to deploy multiple displays across a desktop, build an expansive digital signage wall, or create a sophisticated stereoscopic 3D CAVE environment.
  • NVIDIA NVIEW advanced desktop software
    This software delivers maximum flexibility for single large display or multi-display options, providing unprecedented end-user control of the desktop experience for increased productivity.
  • DisplayPort 1.2 Support (with Audio)
    Compact and secure DisplayPort 1.2 connectors support multi-stream technology, stream cloning and ultra-high-resolution panels (up to 3840 x 2160 at 60Hz). This enables maximum range, resolution, refresh rate, and color depth designed to support the latest display technologies.
  • Quadro Sync
    Synchronizes the display and image output from one system or across a cluster of multiple systems. The Quadro Sync board manages up to 16 displays from 4 GPUs in one system, reducing the number of machines needed to power a video wall or multi-projector visualization environment, and supports image and frame synchronization between up to four GPUs when running Quadro Mosaic or independent GPUs in cluster. Quadro Sync also allows synchronization to an external timing source (also known as genlock or house sync). Quadro Sync enables advanced visualization systems to scale the resolution of the display surface with multiple projectors or displays with standard applications or applications designed for clusters.
  • OpenGL quad buffered stereo support
    Provides a smooth and immersive 3D Stereo experience for professional applications.
  • Professional 3d stereo synchronization
    Enables robust control of stereo effect through a dedicated three-pin mini-din connection to directly synchronize 3D stereo hardware to Quadro graphics card.
  • Deep color processing and display
    Preserve color detail and precision throughout the processing and display pipeline for smooth gradients transitions, even on high dynamic range imagery. Each color component can be processed at up to 32-bit floating point precision and displayed at up to 12-bit precision with supported DisplayPort 1.2 or HDMI 1.4 displays.
NVIDIA Quadro M5000 Sync - graphics card - Quadro M5000 - 8 GB
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
NVIDIA Quadro M5000
8 GB GDDR5
CUDA Cores
2048
Memory Interface
256-bit
Max Resolution
4096 x 2160
Max Resolution Details
DVI: 2560 x 1600 at 60 Hz / DisplayPort: 4096 x 2160 at 60 Hz / VGA: 2048 x 1536 at 85 Hz
Max Monitors Supported
4
DVI-D (dual link) , 4 x DisplayPort , DVI-D (Single-Link) - with adapter , VGA - with adapter
API Supported
OpenCL, DirectCompute, DirectX 12, OpenGL 4.5
26.7 cm x 11.2 cm
Environmental Standards
ENERGY STAR Qualified
3-year warranty
Bundled with
NVIDIA Quadro Sync add-on interface board
Graphics card
Bundled with
Bus Type
PCI Express 3.0 x16
Graphics Engine
NVIDIA Quadro M5000
CUDA Cores
2048
Max Resolution
4
API Supported
Dual Slot Fan Cooler, Nvidia nVIEW Multi-Display Technology, Nvidia CUDA technology, Nvidia GigaThread technology, Nvidia 3D Vision technology, Error Correcting Codes (ECC) Memory, Nvidia Scalable Geometry Engine, NVIDIA Parallel DataCache, NVIDIA Mosaic, Hardware Video Decode Acceleration, Shader Model 5.0, Dolby Digital Plus, Nvidia 3D Vision Pro, 64X Anti-aliasing Technology, Full-Scene Anti-Aliasing (FSAA), GPU Tessellation, NVIDIA GPU Boost, Nvidia Fast Approximate Antialiasing Technology (FXAA), 128-bit floating point HDR rendering, Multi-stream hardware H.264 encoder, OpenGL Quad Buffered Stereo Support, Dynamic Parallelism, Hyper-Q, Nvidia SMX Engine, Nvidia Quadro Mosaic Technology, Quadro Sync, Nvidia GPUDirect, Full 30-bit Display Pipeline, Nvidia Quadro Warp/Blend, Nvidia Temporal Anti-Aliasing Technology (TXAA), Maxwell architecture, 16x angle invariant anisotropic texture filtering, ultra-quiet active fansink, 16K Texture and Render Processing, HDCP
Size
8 GB
GDDR5 SDRAM
Bus Width
256-bit
Bandwidth
211 GBps
Linux, Microsoft Windows Vista, Oracle Solaris, Microsoft Windows 7 / 8 / 8.1 / 10
Min RAM Size
2 GB
Min Hard Drive Space
200 MB
Additional Requirements
DVD-ROM, Internet connection
150 Watt
Stereo connector bracket, 6 pin PCIe power cable, 3 x cable retention clips, 4 x ribbon connector cables
1 x DVI-VGA adapter , 2 x DisplayPort-DVI adapter
Software Included
Display drivers
26.7 cm
11.2 cm
ENERGY STAR Certified
Limited warranty - 3 years
