Product
Brand
PNY NVIDIA Quadro M4000 Sync 8GB GDDR5 PCI-E 3.0 X16 4*DP
Quicklinx: BWFQWS00 Mfr#: VCQM4000SYNC-PB
Get real interactive expression with NVIDIA Quadro - the world's most powerful workstation graphics. Tackle your most demanding visualization workloads with ease using the advanced NVIDIA Maxwell GPU architecture and the flexibility of a single-slot form factor. 8 GB of ultra-fast memory enables the creation and rendering of large, complex models and the computation of massive datasets. A display engine drives up to four 4K resolutions displays natively (4096 x 2160 at 60 Hz with 30-bit color), or pair up two or more outputs to drive displays greater than 4K.
The NVIDIA Quadro Sync board included as part of this turnkey solution synchronizes up to four NVIDIA Maxwell architecture-based GPUs and up to 16 displays or projectors per system. Quadro Sync benefits include the ability to keep multi-projector systems or video walls free of imaging artifacts without impacting performance, the ability to align inputs for multi-input display devices like 4K projectors or panels, proper stereoscopic 3D display across multiple systems, and the ability to align displays or projectors to an external timing source. NVIDIA Mosaic technology support allows any application to scale across synchronized displays or projectors and offers features like projector overlap and an integrated geometry and intensity adjustment to enable pixel-accurate display surfaces.
Designed and built specifically for professional workstations, NVIDIA Quadro GPUs power more than 200 professional applications across a broad range of industries including manufacturing, media and entertainment, sciences, and energy. Professionals trust them to realize their most ambitious visions - whether its product design, visualization and simulation, or spectacular visual storytelling - and get results to market faster.
NVIDIA Quadro M4000 Sync - graphics card - Quadro M4000 - 8 GB
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
NVIDIA Quadro M4000
8 GB GDDR5
CUDA Cores
1664
Memory Interface
256-bit
Max Resolution
4096 x 2160
Max Monitors Supported
4
4 x DisplayPort , DVI-D (Single-Link) - with adapter , DVI-D (dual link) - with adapter
API Supported
OpenCL, DirectCompute, DirectX 12, OpenGL 4.5
24.1 cm x 11.2 cm
Environmental Standards
ENERGY STAR Qualified
3 years warranty
Bundled with
NVIDIA Quadro Sync add-on interface board
Graphics card
Bundled with
Bus Type
PCI Express 3.0 x16
Graphics Engine
NVIDIA Quadro M4000
CUDA Cores
1664
Max Resolution
4
API Supported
Dual Slot Fan Cooler, Nvidia nVIEW Multi-Display Technology, Nvidia CUDA technology, Nvidia GigaThread technology, Nvidia 3D Vision technology, Error Correcting Codes (ECC) Memory, Nvidia Scalable Geometry Engine, NVIDIA Parallel DataCache, NVIDIA Mosaic, Hardware Video Decode Acceleration, Shader Model 5.0, Dolby Digital Plus, Nvidia 3D Vision Pro, 64X Anti-aliasing Technology, Full-Scene Anti-Aliasing (FSAA), GPU Tessellation, NVIDIA GPU Boost, Nvidia Fast Approximate Antialiasing Technology (FXAA), 128-bit floating point HDR rendering, Multi-stream hardware H.264 encoder, OpenGL Quad Buffered Stereo Support, Dynamic Parallelism, Hyper-Q, Nvidia SMX Engine, Nvidia Quadro Mosaic Technology, Quadro Sync, Nvidia GPUDirect, Full 30-bit Display Pipeline, Nvidia Quadro Warp/Blend, Nvidia Temporal Anti-Aliasing Technology (TXAA), Maxwell architecture, 16x angle invariant anisotropic texture filtering, ultra-quiet active fansink, 16K Texture and Render Processing, HDCP
Size
8 GB
GDDR5 SDRAM
Bus Width
256-bit
Bandwidth
192 GBps
Linux, Microsoft Windows Vista, Oracle Solaris, Microsoft Windows 7 / 8 / 8.1 / 10
Min RAM Size
2 GB
Min Hard Drive Space
200 MB
Additional Requirements
DVD-ROM, Internet connection
120 Watt
Stereo connector bracket, 6 pin PCIe power cable, 3 x cable retention clips, 4 x ribbon connector cables
Software Included
Display drivers
24.1 cm
11.2 cm
ENERGY STAR Certified
Limited warranty - 3 years
BWFQ C2G HDMI to DisplayPort Adapter Converter In Stock £35.86
BWFQ C2G 2m DisplayPort Male to HD Male Adapter Cable - Black In Stock £22.05
BWFQ C2G 3m DisplayPort Cable with Latches M/M - Black In Stock £8.17
BWFQ C2G 10m DisplayPort Cable with Latches M/M – Black In Stock £18.16
BWFQ C2G 20cm DisplayPort Male to HDMI Female Adapter Converter Black In Stock £16.15
BWFQ C2G 20cm DisplayPort Male to VGA Female Adapter Converter Black In Stock £12.38
