The NVIDIA Quadro K6000 graphics card is the ultimate expression of NVIDIA's expertise in professional graphics, empowering artists, designers, and engineers to realize their biggest visions. It combines 2880 NVIDIA CUDA parallel processing cores, accelerated double-precision computation, plus the ability to drive up to four ultra-high-resolution displays or projectors. This makes the Quadro K6000 the superior choice to bring your largest and most complex projects to life.
Designed and built specifically for professional workstations, NVIDIA Quadro GPUs power more than 200 professional applications across a broad range of industries including manufacturing, media and entertainment, sciences, and energy. Professionals trust them to realize their most ambitious visions - whether its product design, visualization and simulation, or spectacular visual storytelling - and get results to market faster.
Quad-display support
Display engine drives up to four displays simultaneously and fully supports the DisplayPort 1.2 standard capable of resolutions up to 3840 x 2160. This makes it easy to deploy multiple displays across a desktop, build an expansive digital signage wall, or create a sophisticated stereoscopic 3D CAVE environment. -
Bindles textures
Dramatically increases the number of unique textures available to shaders at run-time, enabling vastly more materials and richer texture detail in scenes. -
NVIDIA SMX
Delivers more processing performance and efficiency through a streaming multiprocessor design that allows a greater percentage of space to be applied to processing cores versus control logic. -
NVIDIA FXAA and TXAA
Reduces visible aliasing and delivers higher image quality without the performance hit by harnessing the power of the GPU's CUDA cores and film-style anti-aliasing techniques.
- NVIDIA Quadro K6000 - graphics card - Quadro K6000 - 12 GB
- Graphics card
- Bus Type
- PCI Express 3.0 x16
- Graphics Engine
- Memory
- 12 GB GDDR5
- CUDA Cores
- 2880
- RAMDAC
- 400 MHz
- Memory Interface
- 384-bit
- Max Resolution
- 3840 x 2160
- Max Resolution Details
- DVI: 2560 x 1600 at 60 Hz / DisplayPort: 3840 x 2160 at 60 Hz / VGA: 2048 x 1536 at 85 Hz
- Max Monitors Supported
- 4
- DVI-I (dual link) , DVI-D (dual link) , 2 x DisplayPort , VGA - with adapter , 2 x DVI-D (Single-Link) - with adapter
- API Supported
- DirectX 11, OpenCL, DirectCompute 5.0, OpenGL 4.3
- 26.7 cm x 11.1 cm
- Environmental Standards
- ENERGY STAR Qualified
- 3-year warranty
- Bundled with
- NVIDIA Quadro Sync add-on interface board
- Graphics card
- Bundled with
- Bus Type
- Graphics Engine
- CUDA Cores
- 2880
- RAMDAC
- 400 MHz
- Max Resolution
- 3840 x 2160
- 4
- API Supported
- Dual Slot Fan Cooler, Nvidia nVIEW Multi-Display Technology, Nvidia CUDA technology, Nvidia GigaThread technology, Nvidia 3D Vision technology, Error Correcting Codes (ECC) Memory, Nvidia Scalable Geometry Engine, NVIDIA Parallel DataCache, NVIDIA Mosaic, Shader Model 5.0, Dolby Digital Plus, Nvidia 3D Vision Pro, 64X Anti-aliasing Technology, TXAA, FXAA, Dual-stream Hardware Acceleration, Dual Copy Engines, Full-Scene Anti-Aliasing (FSAA), GPU Tessellation, Large Framebuffers with Ultra-Fast Bandwidth, Kepler GPU Architecture, OpenGL Quad Buffered Stereo Support, NVIDIA Maximus technology, Nvidia SMX Engine, Nvidia Quadro Mosaic Technology, Quadro Sync, Nvidia GPUDirect, Bindless Textures, HDCP
- Size
- 12 GB
- Technology
- GDDR5 SDRAM
- Bus Width
- 384-bit
- Bandwidth
- 288 GBps
- OS Required
- Linux, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits) SP3, Oracle Solaris, Windows 8 (32/64 bits)
- Min RAM Size
- 1 GB
- Min Hard Drive Space
- 200 MB
- Additional Requirements
- DVD-ROM
- 225 Watt
- Included Accessories
- Stereo connector bracket, 3 x 6 pin power cables, 6 cable retention clips
- Cables Included
- 1 x DVI-VGA adapter , 2 x DisplayPort-DVI adapter
- Software Included
- Drivers & Utilities
- 26.7 cm
- 11.1 cm
- ENERGY STAR Certified
- Limited warranty - 3 years
