NVIDIA Quadro K1200 - Incredible 3D application performance in a flexible form factor. Now included in the box, a full-height bracket lets this single-slot and low-profile board fit into any full-height (ATX) desktop, mid-tower, or desk side tower enclosure. The Quadro K1200 is the perfect choice for Manufacturing or Media & Entertainment professionals who are transitioning to 4K applications, workflows, and photorealistic HDR (High Dynamic Range) rendering enabled by NVIDIA Iray. 512 CUDA cores and 4 GB of GDDR5 GPU memory with fast bandwidth enables your customers to create large, complex 3D models, and an all-new display engine drives up to four displays natively with DisplayPort 1.2 support for true 4K resolutions like 3840 x 2160 at 60 Hz with 30-bit color. Designed and built specifically for professional workstations, NVIDIA Quadro GPUs power more than 100+ professional applications across a broad range of industries including manufacturing, media and entertainment, sciences, and energy. Professionals trust them to realize their most ambitious visions - whether its product design, visualization and simulation, or spectacular visual storytelling - and get results to market faster. PNY provides unsurpassed service and commitment to its professional graphics customers offering: pre and post-sales support, dedicated Quadro Field Application engineers and direct tech support hot lines. In addition, PNY delivers a complete solution including the appropriate adapters, cables, brackets, software installation disc and documentation to ensure a quick and successful install.
Energy-efficient design
With ENERGY STAR certification, this graphics card ensures optimal energy efficiency, reducing power consumption and lowering energy costs while maintaining performance. -
High-quality visuals
Equipped with a 128-bit bus width and GDDR5 SDRAM technology, the NVIDIA Quadro K1200 delivers exceptional bandwidth of 80 GBps for handling complex graphics with ease. -
Enhanced connectivity
Featuring four Mini DisplayPort interfaces with an adapter for DisplayPort connections, this graphics card offers versatile connectivity options for multiple display setups. -
Advanced video support
Supports a wide range of APIs including DirectCompute, DirectX 12, OpenCL, and OpenGL 4.5, enabling compatibility with a wide range of multimedia applications and games. -
Optimized for professional use
From its low-profile design to support for up to four monitors and ultra-quiet active fansink, the NVIDIA Quadro K1200 is engineered for professionals seeking a powerful yet compact graphics solution.
- NVIDIA Quadro K1200 for DisplayPort - graphics card - Quadro K1200 - 4 GB
- Graphics card - low profile
- Bus Type
- PCI Express 2.0 x16
- Graphics Engine
- Memory
- 4 GB GDDR5
- CUDA Cores
- 512
- Memory Interface
- 128-bit
- Max Resolution
- 3840 x 2160
- Max Monitors Supported
- 4
- 4 x Mini DisplayPort , 4 x DisplayPort - with adapter
- API Supported
- OpenCL, DirectCompute, DirectX 12, OpenGL 4.5
- 16 cm x 6.86 cm
- Environmental Standards
- ENERGY STAR Qualified
- 3-year warranty
- Bus Type
- Graphics Engine
- CUDA Cores
- 512
- Max Resolution
- 3840 x 2160 at 60 Hz
- 4
- API Supported
- Nvidia SLI Multi-GPU Technology, NVIDIA Unified Driver Architecture (UDA), Nvidia nVIEW Multi-Display Technology, Nvidia CUDA technology, Nvidia 3D Vision technology, Nvidia Scalable Geometry Engine, NVIDIA Parallel DataCache, NVIDIA Mosaic, Deep Color technology, Dolby True HD support, DTS-HD Master Audio support, Hardware Video Decode Acceleration, Shader Model 5.0, Dolby Digital Plus, Full-Scene Anti-Aliasing (FSAA), GPU Tessellation, Large Framebuffers with Ultra-Fast Bandwidth, NVIDIA GPU Boost, Nvidia Fast Approximate Antialiasing Technology (FXAA), Multi-stream hardware H.264 encoder, OpenGL Quad Buffered Stereo Support, Nvidia Quadro Mosaic Technology, Bindless Textures, Nvidia Temporal Anti-Aliasing Technology (TXAA), ultra-quiet active fansink, HDCP
- Size
- 4 GB
- Technology
- GDDR5 SDRAM
- Bus Width
- 128-bit
- Bandwidth
- 80 GBps
- OS Required
- SunSoft Solaris, Linux, Microsoft Windows XP SP3, Microsoft Windows Vista / 7 / 8 / 8.1
- Min RAM Size
- 2 GB
- Min Hard Drive Space
- 200 MB
- Additional Requirements
- DVD-ROM
- 45 Watt
- Included Accessories
- Full-height bracket
- Cables Included
- 4 x Mini DisplayPort-DisplayPort adapter
- Software Included
- Drivers & Utilities
- 16 cm
- 6.86 cm
- ENERGY STAR Certified
- Limited warranty - 3 years
