This advanced gaming GPU is powered by the high-performance, energy-efficient architecture. The architecture enables truly game-changing performance with captivating sights and sounds, as well as amazing VR performance, that offers the low latency and Plug and Play compatibility with headsets.
Amazing gaming platform
Driven by the NVIDIA Pascal architecture, the GeForce GTX 1080 delivers the amazing performance, advanced gaming technologies, and immersive VR. -
Excellent performance
The GeForce GTX 1080 is a quantum leap in performance and power efficiency. It's built using ultra-fast FinFET and high-bandwidth technologies, and supports DirectX 12 features for the fast, smooth, power-efficient gaming experiences. -
NVIDIA Pascal
GeForce GTX 1080 uses the power of Pascal to meet the demands of the displays, including VR, ultra-high-resolution, and multiple monitors. It features NVIDIA GameWorks technologies for smooth gameplay and cinematic experiences, as well as 360-degree image capture - even in VR. -
VR ready
Discover VR performance, the low latency, and Plug and Play compatibility with headsets - driven by NVIDIA VRWorks technologies. VR audio, physics, and haptics let you hear and feel every moment. -
Outstanding design
The GeForce GTX 1080 is meticulously crafted to offer superior heat dissipation, using an advanced vapor chamber and premium materials, so it runs as cool as it looks.
- PNY GeForce GTX 1080 - XLR8 OC GAMING Edition - graphics card - GF GTX 1080 - 8 GB
- Graphics card
- Bus Type
- PCI Express 3.0 x16
- Graphics Engine
- NVIDIA GeForce GTX 1080
- Memory
- 8 GB GDDR5X
- Core Clock
- 1708 MHz
- Boost Clock
- 1848 MHz
- CUDA Cores
- 2560
- Memory Interface
- 256-bit
- Max Resolution
- 7680 x 4320
- Interfaces Details
- DVI , 3 x DisplayPort , HDMI
- API Supported
- DirectX 12, OpenGL 4.5, Vulkan
- 4 cm x 30 cm x 11 cm
- 3-year warranty
- Graphics card
- Bus Type
- Graphics Engine
- Core Clock
- 1708 MHz
- Boost Clock
- 1848 MHz
- CUDA Cores
- 2560
- VR Ready
- Max Resolution
- 7680 x 4320 at 60 Hz
- API Supported
- Nvidia CUDA technology, NVIDIA G-Sync ready, NVIDIA GameStream, Nvidia GeForce GTX VR Ready, NVIDIA GPU Boost 3.0, simultaneous multi-projection, NVIDIA Ansel, Nvidia SLI with HB Bridge Support, HDCP
- Size
- 8 GB
- Technology
- GDDR5X SDRAM
- Bus Width
- 256-bit
- OS Required
- Linux, FreeBSD (32-bit), Microsoft Windows 7 / 8 / 8.1 / 10
- Required Power Supply
- 550 W
- Additional Requirements
- Internet connection, 8 pin PCI Express power connector
- 190 Watt
- 4 cm
- 30 cm
- 11 cm
- Limited warranty - 3 years
C2G 3m DisplayPort Cable with Latches M/M - Black | In Stock | £13.17 |
