The PNY GeForce GTX 1060 graphics card is loaded with innovative gaming technologies, making it the perfect choice for the high-definition games. Powered by NVIDIA Pascal - the advanced GPU architecture - the GeForce GTX 1060 delivers brilliant performance that opens the door to virtual reality and beyond. This advanced graphics card is created with ultra-fast FinFET technology and supports DirectX 12 features to deliver fast, smooth, power-efficient gaming experiences.
- PNY GeForce GTX 1060 - graphics card - GF GTX 1060 - 3 GB
- Graphics card
- Bus Type
- PCI Express 3.0 x16
- Graphics Engine
- NVIDIA GeForce GTX 1060
- Memory
- 3 GB GDDR5
- Core Clock
- 1506 MHz
- Boost Clock
- 1708 MHz
- CUDA Cores
- 1152
- Memory Interface
- 192-bit
- Max Resolution
- 7680 x 4320
- Interfaces Details
- DVI , 3 x DisplayPort , HDMI
- API Supported
- DirectX 12, OpenGL 4.5, Vulkan
- 4.2 cm x 25.4 cm x 12.7 cm
- 3-year warranty
- Graphics card
- Bus Type
- Graphics Engine
- Core Clock
- 1506 MHz
- Boost Clock
- 1708 MHz
- CUDA Cores
- 1152
- VR Ready
- Max Resolution
- 7680 x 4320 at 60 Hz
- API Supported
- NVIDIA G-Sync ready, NVIDIA GameStream, NVIDIA GameWorks, Nvidia GeForce GTX VR Ready, NVIDIA GPU Boost 3.0, NVIDIA Ansel, HDCP
- Size
- 3 GB
- Technology
- GDDR5 SDRAM
- Bus Width
- 192-bit
- Required Power Supply
- 400 W
- Additional Requirements
- 6 pin PCI Express power connector
- 120 Watt
- 4.2 cm
- 25.4 cm
- 12.7 cm
- Limited warranty - 3 years
C2G 3m DisplayPort Cable with Latches M/M - Black | In Stock | £12.92 |
