PNY GeForce GT 710 2GB DDR3 PCIe 2.0 x8 DVI D-Sub
Quicklinx: CDX8WS00 Mfr#: GF710GTLH2GEPB
Make your entire PC experience faster with the NVIDIA GeForce GT 710 by PNY dedicated graphics card. Now, you can enjoy up to 10x better performance than integrated graphics in all your PC multimedia applications.
Take on modern games with advanced and reliable dedicated graphics. 80% faster performance than integrated graphics means a rich and smooth gaming experience. Plus, get the power to drive up to three HD displays with a single card.
GeForce GT means speed, stability, and industry-leading NVIDIA drivers. Tap into GeForce Experience to automatically get the drivers and optimize game settings with a single click.
  • SMX
    Next-generation streaming multiprocessor built from the ground up for incredible performance and power efficiency.
  • NVIDIA PureVideo HD technology
    The combination of high-definition video decode acceleration and post-processing that delivers stunning picture clarity, smooth video, accurate color, and precise image scaling for movies and video.
  • TrueHD and DTS-HD Audio Bitstreaming
    Full support for TrueHD and DTS-HD advanced lossless multi-channel HD audio codecs brings the rich sound of the master recording to your living room.
  • GeForce Experience
    Ensures the best gaming experience, the day a game releases, by automatically updating your game-ready drivers. Plus, GeForce Experience allows users to optimize the game settings to their PC with a single click.
  • NVIDIA PhysX technology
    Enables a totally new class of physical gaming interaction for a more dynamic and realistic experience with GeForce.
  • NVIDIA Adaptive Vertical Sync
    Dynamically enables vertical sync based on your current frame rates for the smoothest gaming experience.
  • NVIDIA FXAA technology
    Shader-based anti-aliasing technology available from the NVIDIA Control Panel that enables ultra-fast anti-aliasing in hundreds of PC games.
  • NVIDIA CUDA technology
    Unlocks the power of the GPU's processor cores to accelerate the most demanding tasks such as video transcoding, physics simulation, ray tracing, and more, delivering incredible performance improvements over traditional CPUs.
  • HDMI
    Support for HDMI including GPU accelerated Blu-ray 3D support, x.v. Color, HDMI Deep Color, and 7.1 digital surround sound.
  • Dual-link DVI
    Able to drive flat-panel displays up to 2560 x 1600 resolution over a DVI connector.
PNY GeForce GT 710 - graphics card - GF GT 710 - 2 GB
Graphics card - low profile
Bus Type
PCI Express 2.0 x8
Graphics Engine
2 GB DDR3
Core Clock
954 MHz
CUDA Cores
192
Memory Interface
64-bit
Max Resolution
4096 x 2160
Max Monitors Supported
3
HDMI , VGA , DVI-D (dual link)
API Supported
OpenCL, DirectX 12, OpenGL 4.5
3-year warranty
Bus Type
PCI Express 2.0 x8
Graphics Engine
Core Clock
954 MHz
CUDA Cores
192
Max Resolution
4096 x 2160
3
API Supported
Nvidia GeForce 3D Vision Ready, Nvidia CUDA technology, Nvidia PhysX-Ready, FXAA, NVIDIA Adaptive Vertical Sync
Size
2 GB
DDR3 SDRAM
Bus Width
64-bit
Microsoft Windows XP / Vista / 7 / 8 / 10 (32/64 bits)
Min RAM Size
2 GB
Required Power Supply
300 W
Additional Requirements
Internet connection
22 Watt
RoHS, REACH
Limited warranty - 3 years
CDX8 C2G 1m DVI-D™ M/M Dual Link Digital Video Cable In Stock £8.20
CDX8 C2G 2m DVI-D™ M/M Dual Link Digital Video Cable In Stock £9.58
CDX8 C2G 5m DVI-D™ M/M Dual Link Digital Video Cable In Stock £17.40
CDX8 C2G Velocity™ DVI-D™ Male to HDMI® Female Inline Adapter In Stock £5.00
CDX8 C2G USB to DVI Adapter Up To 2048 x 1152 In Stock £40.16
CDX8 C2G 2m HDMI to DVI-D Digital Video Cable In Stock £8.91
