PNY CS1311 Series 2.5" SATA III 960GB SSD
Quicklinx: C4WQWS00 Mfr#: SSD7CS1311-960-RB
The CS1311 SSD is a 2.5" SATA III 7mm internal Solid-State Drive (SSD) from PNY’s CS1300 Value Family of Solid State Drives. The PNY CS1311 is an ideal SSD for reviving your laptop or desktop to experience the true speed of your PC or Mac. Maximize the existing investment in your computer by upgrading to the CS1311, and see a dramatic improvement in boot-up time, application loads, and the overall responsiveness of your system. The affordable and fast PNY CS1311 delivers the performance you want, at a cost-efficient price point.
Trusted Performance
Upgrade to a PNY SSD to experience PC performance that's up to 24x faster than a traditional HDD. Featuring no moving parts, PNY SSDs complete random operations rapidly. You PC will feel brand new with faster boot up time, quick application launch, and a better overall computing experience.
Quality Assurance
All PNY SSDs undergo extensive component and sub-system testing. We utilize high-quality NAND from the industry’s top vendors to ensure a solid SSD. Our SSDs are validated across applications and environments to ensure they meet the highest quality, reliability, and durability criteria.
Proven Reliability
Our SSDs undergo some of the most rigorous durability and validation testing in the industry, withstanding hundreds of qualification tests and over 10,000 hours of validation testing. Each SSD is guaranteed to meet the requirements of even the most demanding applications.
3-Year Warranty
With stringent endurance standards in place, PNY stands behind our SSDs - which is proven with our competitive three year warranty. In addition, our US-based technical support team is available 24/7 to answer your questions.
Cool and Quiet Operation
Generating less heat than an HDD, PNY SSDs ultimately increase the life of your PC. Our SSDs reduce operating temperature and potential damage from overheating. Additionally, SSDs don’t produce any noise, making your PC significantly quieter.
Energy Efficient
PNY SSDs feature low-wattage and function with an advanced lower-power mode. On average, PNY SSDs consume 30% less power than HDDs. If you’re aiming to build a silent, green PC, PNY SSDs are a must have on item your checklist.
Shock Proof
PNY SSDs are up to 30 times more robust than HDDs, making it less likely to fail in extreme environments, including high and low temperatures. The non-volatile NAND in the system enables the SSD to retain its memory if your computer ever falls or is dropped.
Built by Experts
PNY is an SSD solution provider with lifecycle product management to JEDEC standards. With a world class SSD engineering team based in Silicon Valley, we are well positioned to take advantage of emerging technologies.
  • Trusted performance
    Experience blazing fast performance when you upgrade to a PNY SSD for a much faster PC performance. PNY SSDs feature no moving parts to complete random operations rapidly. Get faster boot up time, enabling your PC to perform better. Applications launch quicker than ever and programs load in seconds, for a better overall computing experience.
  • Cool and quiet operation
    PNY SSDs enable cool and quiet operation, ultimately increasing the life of your PC. With no moving parts, these SSDs generate less heat than an HDD, reducing operating temperature and potential damage from overheating. Along with a lower temperature, SSDs don't produce any noise, and can make your PC significantly quieter.
  • Energy efficient
    PNY SSDs have no moving parts, feature low wattage, and function with an advanced lower-power mode. PNY SSDs consume less power than HDDs. If you're aiming to build a silent, green PC, PNY SSDs are a must have on item your checklist.
  • Shock proof
    PNY SSDs are very robust and can withstand, bumps, falls, and feature no moving parts - making them less likely to fail. PNY SSDs thrive and survive in extreme environments, high and low temperatures, high humidity, and the non-volatile NAND in the system enables the SSD to retain its memory in case of impact and shock if your computer ever falls or is dropped.
PNY CS1311 - SSD - 960 GB - SATA 6Gb/s
Solid state drive - internal
960 GB
NAND Flash Memory Type
Triple-level cell (TLC)
2.5"
SATA 6Gb/s
Data Transfer Rate
600 MBps
Native Command Queuing (NCQ), shock resistant, TRIM support, Error Correction Code (ECC), End-to-end data path protection, boot drive, power management support, Enhanced Secure Erase, S.M.A.R.T.
70 mm x 100 mm x 7 mm
45 g
3-year warranty
960 GB
2.5"
SATA 6Gb/s
70 mm
100 mm
7 mm
45 g
Performance
Drive Transfer Rate
600 MBps (external)
Reliability
MTBF
2,000,000 hours
Expansion & Connectivity
1 x SATA 6 Gb/s - 7 pin Serial ATA
Compatible Bay
2.5"
Power Consumption
2.2 Watt (active) , 0.17 Watt (idle)
Linux, Apple MacOS X, Ubuntu 14, Microsoft Windows XP / Vista / 7 / 8 / 10, CentOS 7.0
FCC, RoHS
Package Type
Retail
Limited warranty - 3 years
70 °C
