The CS1311 SSD is a 2.5" SATA III 7mm internal Solid-State Drive (SSD) from PNY’s CS1300 Value Family of Solid State Drives. The PNY CS1311 is an ideal SSD for reviving your laptop or desktop to experience the true speed of your PC or Mac. Maximize the existing investment in your computer by upgrading to the CS1311, and see a dramatic improvement in boot-up time, application loads, and the overall responsiveness of your system. The affordable and fast PNY CS1311 delivers the performance you want, at a cost-efficient price point.
Trusted Performance
Upgrade to a PNY SSD to experience PC performance that's up to 24x faster than a traditional HDD. Featuring no moving parts, PNY SSDs complete random operations rapidly. You PC will feel brand new with faster boot up time, quick application launch, and a better overall computing experience.
Quality Assurance
All PNY SSDs undergo extensive component and sub-system testing. We utilize high-quality NAND from the industry’s top vendors to ensure a solid SSD. Our SSDs are validated across applications and environments to ensure they meet the highest quality, reliability, and durability criteria.
Proven Reliability
Our SSDs undergo some of the most rigorous durability and validation testing in the industry, withstanding hundreds of qualification tests and over 10,000 hours of validation testing. Each SSD is guaranteed to meet the requirements of even the most demanding applications.
3-Year Warranty
With stringent endurance standards in place, PNY stands behind our SSDs - which is proven with our competitive three year warranty. In addition, our US-based technical support team is available 24/7 to answer your questions.
Cool and Quiet Operation
Generating less heat than an HDD, PNY SSDs ultimately increase the life of your PC. Our SSDs reduce operating temperature and potential damage from overheating. Additionally, SSDs don’t produce any noise, making your PC significantly quieter.
Energy Efficient
PNY SSDs feature low-wattage and function with an advanced lower-power mode. On average, PNY SSDs consume 30% less power than HDDs. If you’re aiming to build a silent, green PC, PNY SSDs are a must have on item your checklist.
Shock Proof
PNY SSDs are up to 30 times more robust than HDDs, making it less likely to fail in extreme environments, including high and low temperatures. The non-volatile NAND in the system enables the SSD to retain its memory if your computer ever falls or is dropped.
Built by Experts
PNY is an SSD solution provider with lifecycle product management to JEDEC standards. With a world class SSD engineering team based in Silicon Valley, we are well positioned to take advantage of emerging technologies.
Tough and long-lasting
With no moving parts, your computer can better withstand drops, bumps, and crashes. -
Low power consumption
Built with a great flash memory, PNY SSDs consume significantly less power. -
Lightweight
Flash-based SSDs are very light, providing you with greater overall portability. -
Cool, quiet operation
Keep your PC cool and quiet with an energy-efficient SSD that won't overheat.
- PNY CS1311 - solid state drive - 240 GB - SATA 6Gb/s
- Solid state drive - internal
- Capacity
- 240 GB
- NAND Flash Memory Type
- Triple-level cell (TLC)
- Form Factor
- 2.5"
- Interface
- SATA 6Gb/s
- Data Transfer Rate
- 600 MBps
- Shock resistant, ToughMount anti-shock protection, TRIM support, S.M.A.R.T.
- 70 mm x 100 mm x 7 mm
- 80 g
- 3-year warranty
- Capacity
- 240 GB
- Form Factor
- 2.5"
- Interface
- SATA 6Gb/s
- 70 mm
- 100 mm
- 7 mm
- 80 g
Performance
- Drive Transfer Rate
- 600 MBps (external)
- Internal Data Rate
- 560 MBps (read) / 500 MBps (write)
- 4KB Random Read
- 80000 IOPS
- 4KB Random Write
- 70000 IOPS
Reliability
- MTBF
- 2,000,000 hours
Expansion & Connectivity
- 1 x SATA 6 Gb/s - 7 pin Serial ATA
- Compatible Bay
- 2.5"
- Power Consumption
- 2.5 Watt (active) , 0.2 Watt
- OS Required
- Linux, Apple MacOS X, Microsoft Windows 7, Microsoft Windows Vista, Windows 8.1
- Limited warranty - 3 years
