Your basket is empty
PMVmounts Peerless-AV
Large Universal Tilting Wall Mount for 37" to 65" Displays
PMVmounts Peerless-AV Large Universal Tilting Wall Mount for 37" to 65" Displays
Quicklinx: B74BWS00 Mfr#: PMVMOUNT2036T
Marketing description is not available.
PMV Mounts PMVMOUNT2036T - wall mount
Wall mount
69 cm 42.7 cm
Tilt
-7.5° to 7.5°
Recommended Use
LCD / plasma panel
Recommended Display Size
32"-65"
Flat Panel Mount Interface
400 x 400 mm, 600 x 400 mm, 300 x 400 mm, 200 x 400 mm
Max Load Weight
75 kg
Black satin powder coat
69 cm
42.7 cm
AV Furniture
Wall mount
Mounting Components
Wall mount
Recommended Use
LCD / plasma panel
32"-65"
Tilt
-7.5° to 7.5°
Max Load Weight
75 kg
