Product
Plustek PL806
Plustek PL806
Quicklinx: BLGVWS00 Mfr#: 0123UK
PL806 ADF document scanner offers high-speed scanning capability and compact design, making it a perfect solution for workgroups and other decentralized scanning applications.
PL806 ADF scanner provides a maximum scanning speed of 8 pages per minute, optical resolution of up to 600 dpi, and identifies large quantities of documents at high speed by built-in Auto Document Feeder (ADF) that holds up to 50 pages per time.
Besides, it can be used as regular flatbed scanners easily, which adds ever more versatility to satisfy all your needs. This PL806 ADF scanner is a truly versatile document scanner that puts up outstanding value and high performance, making it a perfect business and SOHO solution, and enables businesses to achieve high levels of productivity.
  • Magnificent ideal design
    The perfect mechanical design of the PL806 ADF scanner is for superior image focus and diminishing paper jam. With the Optical Character Recognition (OCR) software, PL806 ADF document scanner yields results into a word processor with more accuracy.
  • Easy to use
    The intelligent Plustek PL806 ADF document scanner product with an improved TWAIN driver permits a simple scanning process just like photocopier; its auto detector function is capable of the scanning auto preview
  • High accuracy
    With Auto Document Feeder (ADF) availability, PL806 ADF scanner is capable of feeding 50 pages per time. Furthermore, with the same function as normal photocopier, the PL806 ADF scanner also processes the flatbed operation.
  • TWAIN support
    Features industry standard TWAIN drivers that are supported by thousands of document management and imaging applications.
Plustek SmartOffice PL806 - document scanner - desktop - USB 2.0
Document scanner - desktop
Interface Type
USB 2.0
Max Supported Document Size
220 x 356 mm
United Kingdom
Input Type
Optical Resolution
600 dpi x 1200 dpi
Max Document Scan Speed
8 ppm (mono) / 8 ppm (colour)
Max Document Size
220 mm x 356 mm
Supported Document Type
Plain paper
Document Feeder Type
Automatic
Document Storage Capacity
50 sheets
Duty Cycle
1000 scans per day
Microsoft Windows 2000, Microsoft Windows XP, Microsoft Windows 7, Microsoft Windows Vista
46.8 cm x 34.7 cm x 17.5 cm
4.8 kg
Interface Type
USB 2.0
220 x 356 mm
United Kingdom
Scanner
Input Type
Optical Resolution
600 dpi x 1200 dpi
Max Document Scan Speed B/W
8 ppm
Max Document Scan Speed Colour
8 ppm
Control Panel Buttons Functions
Scan, copy, file, OCR, Custom
Duty Cycle
1000 scans per day
Scanner Speed Details
8 ppm - colour - A4 - 200 dpi , 8 ppm - greyscale - A4 - 200 dpi , 8 ppm - black & white - A4 - 200 dpi
TWAIN
Media Handling
Max Document Size
220 mm x 356 mm
Plain paper
Automatic
50 sheets
USB 2.0
External power adapter
Software Included
ABBYY FineReader 6.0 Sprint Plus, Plustek DI Capture, Plustek DocAction, NewSoft Presto! ImageFolio 4.5, NewSoft Presto! PageManager 7.10, Plustek DocTWAIN
System Requirements Details
Pentium III - 1 GHz - RAM 256 MB - HD 800 MB
46.8 cm
34.7 cm
17.5 cm
4.8 kg
