The PL7000 provides you the fastest and most efficient software for your documents management. The PL7000 is a new member of Smart Office series, offering the high-speed scanning capability and compact design for workgroups and other decentralized scanning applications. The PL7000 is a versatile high-speed scanner for personal or business users looking to increase their efficiency while on a limited budget. It has a built-in Auto Document Feeder (ADF) that holds up to 80 pages at a time while providing a maximum scanning speed of 70 pages per minute, optical resolution up to 600 dpi, and features USB 2.0 compatibility. Fully automated buttons on front panel - Scans a stack of pictures, files them, saves in your preferred format, and at the dpi you want.
An extension to the popular Smart Office line, the PL7000 breaks the "speed barrier" by delivering up the high speed of self-fed document scanning. Ideal for small office/home office (SOHO) users or the heavy corporate user (such as hospitals, law firms, CPA firms, banks and other financial institutions) this new document scanner is designed to provide maximum utility with minimum effort.
Magnificent ideal design
The perfect mechanical design of the PL7000 is for superior image focus and diminishing paper jam. -
Fast
In this rapidly changing era, using PL7000 scanner can save your time with more efficiency and accuracy with its 70 pages per minute scanning capability. -
Easy to use
The intelligent Plustek PL7000 ADF document scanner product with an improved TWAIN driver permits a simple scanning process just like photocopier. Its auto detector function is capable of the scanning auto preview. -
Multifunctional scanning ability
With Auto Document Feeder (ADF) availability, PL7000 ADF scanner is capable of 70 pages per minute with incredible paper size. Furthermore, it has the same function as a normal photocopier or a flatbed scanner.
- Plustek SmartOffice PL7000 - document scanner - desktop - USB 2.0
- Document scanner - desktop
- Interface Type
- USB 2.0
- Scanning Sensor Type
- CCD
- Max Supported Document Size
- 216 x 355.6 mm
- Input Type
- Grayscale / Color Depth
- 16-bit (64K grey levels) / 48-bit colour
- Grayscale / Color Depth (External)
- 8-bit (256 grey levels) / 24-bit (16.7 million colours)
- Optical Resolution
- 600 dpi
- Max Document Scan Speed
- 70 ppm (mono)
- Max Document Size
- 216 mm x 355.6 mm
- Supported Document Type
- Plain paper
- Document Feeder Type
- Automatic
- Document Storage Capacity
- 80 sheets
- System Requirements
- Microsoft Windows XP Professional SP1, Microsoft Windows XP Home Edition SP1, Microsoft Windows 2000 SP4
- Microsoft Certification
- Certified for Windows Vista
- 5.5 kg
- Interface Type
- USB 2.0
- 216 x 355.6 mm
Scanner
- Input Type
- Grayscale Depth
- Grayscale Depth (External)
- Colour Depth
- 48-bit colour
- Colour Depth (External)
- 24-bit (16.7 million colours)
- 600 dpi
- Scan Mode
- Single-pass
- CCD
- Max Document Scan Speed B/W
- 70 ppm
- Scanner Speed Details
- 70 ppm - greyscale - A4 - 200 dpi
- TWAIN
Media Handling
- Max Document Size
- 216 mm x 355.6 mm
- Plain paper
- Automatic
- 80 sheets
- USB 2.0 - Type B
- Cables Included
- 1 x USB cable
- Certified for Windows Vista software and devices have undergone compatibility tests for ease-of-use, better performance and enhanced security.
- UL, TUV GS, C-Tick, cUL, CB, FCC
- Power Device
- External power adapter
- Software Included
- Drivers & Utilities, Presto! PageManager, Presto! ImageFolio, Readiris Pro 10 Corporate Edition
- OS Required
- Additional Requirements
- CD-ROM, USB port
- System Requirements Details
- Pentium III - 1 GHz - RAM 256 MB - HD 800 MB
- 5.5 kg
