Plustek Opticbook 3800
Quicklinx: 8MXQWS00 Mfr#: 0205UK
Type: Flatbed scanner
Form Factor: Desktop
Max Paper Size: 216 x 297 mm
Interface: USB 2.0
Compatibility: PC
Hurry, only 2 left in stock!
£145.18 ex VAT
£174.21 inc VAT
OpticBook 3800 is an efficient and compact professional book scanner in the market. OpticBook 3800 comes with a unique book edge design that allows a book to lying completely flat on the scanning glass, also with one-touch button design operation, create searchable PDF file, great for file management and preserving documents, easy and simple to use!
OpticBook 3800 is suitable for libraries, students, teachers, universities, law firms, publicists or any book enthusiast!
  • Book edge design
    The book edge unique design eliminates the book spine shadow and text distortion of traditional books while copying and scanning. The intelligent design avoids the need for a large, expensive overhead scanner or complicated image-editing software.
  • LED light source
    It features green design: LED light source, power saving and non-toxic material using.
  • High-scanning speed
    It features high-scanning speed at 300 dpi for an A4 size color page.
  • Function buttons
    One-touch buttons for performing pre-set functions and speed up the scanning time for more efficiency.
Plustek OpticBook 3800 - flatbed scanner - desktop - USB 2.0
Flatbed scanner - desktop
Interface Type
USB 2.0
Scan Element Type
CCD
Light Source
Xe-gas cold cathode fluorescent lamp
Max Supported Document Size
216 x 297 mm
United Kingdom
Input Type
Grayscale / Color Depth
16-bit (64K grey levels) / 48-bit colour
Grayscale / Color Depth (External)
8-bit (256 grey levels) / 24-bit (16.7 million colours)
Optical Resolution
1200 dpi
Scan Speed
7 sec / scan
Max Document Size
216 mm x 297 mm
Supported Document Type
Plain paper, bulk objects (such as books, magazines and other bound materials)
Duty Cycle
2500 scans per day
Microsoft Windows 2000/XP/Vista/7
Microsoft Certification
Compatible with Windows 7
45.3 cm x 28.5 cm x 10.5 cm
3.4 kg
Interface Type
USB 2.0
216 x 297 mm
United Kingdom
Scanner
Input Type
Grayscale Depth
Grayscale Depth (External)
Colour Depth
48-bit colour
Colour Depth (External)
Optical Resolution
1200 dpi
Scan Element Type
CCD
Bulb / Light Source Type
Scan Speed
7 sec / scan
Duty Cycle
2500 scans per day
TWAIN
Media Handling
Max Document Size
216 mm x 297 mm
USB 2.0
RoHS, WEEE
External power adapter
Power Consumption Operational (Standby)
18 Watt (4.3 Watt)
Software Included
NewSoft Presto! ImageFolio 4.5, ABBYY FineReader 9.0 Sprint, Plustek Book Pavilion, Plustek DocTWAIN, NewSoft Presto! PageManager 7.23, Plustek DI Express 6
System Requirements Details
Pentium 4 - 2 GHz - RAM 512 MB - HD 800 MB
45.3 cm
28.5 cm
10.5 cm
3.4 kg
Interface: USB 2.0
Compatibility: PC
Brand: Plustek
Price Range Ex VAT: 100 - 150
