Product
Plustek Optic Film 8200i AI
Quicklinx: BLH1WS00 Mfr#: 0227UK
Type: Film scanner (35 mm)
Form Factor: Desktop
Max Paper Size: Film 135 (35mm)
Interface: USB 2.0
Compatibility: Mac, PC
£293.46 ex VAT
£352.15 inc VAT
Plustek OpticFilm 8200i Ai is a powerful scanner with 7200 dpi resolution. Its sharp optical system produces excellent detail in shadow areas and remarkable tonal range. A built-in infrared channel helps users remove dust and scratches on the original negatives and slides without additional post-processing. With the IT 8 calibration slide, this powerful scanner consistently delivers accurate colors and detail.
The Plustek OpticFilm 8200i Ai gets professional quality results from any photographic original. It is used by professional photographers, amateur photographers, graphic designers, image enthusiasts, and those who highly demand image quality on photo enlargements.
Plustek OpticFilm 8200i Ai - film scanner (35 mm) - desktop - USB 2.0
Film scanner (35 mm) - desktop
Interface Type
USB 2.0
Scan Element Type
CCD
Light Source
LED
Max Supported Document Size
Film 135 (35mm)
United Kingdom
Input Type
Grayscale / Color Depth
16-bit (64K grey levels) / 48-bit colour
Grayscale / Color Depth (External)
Optical Resolution
7200 dpi x 7200 dpi
Max Document Size
36.8 mm x 25.4 mm
Supported Document Type
Slides, film
Apple MacOS X 10.6, Microsoft Windows Vista / XP / 7, Apple MacOS X 10.5, Apple MacOS X 10.7 Lion, Windows 8, Apple MacOS X 10.8
Microsoft Certification
Compatible with Windows 7
12 cm x 27.2 cm x 11.9 cm
1.6 kg
Environmental Standards
ENERGY STAR Qualified
Interface Type
USB 2.0
Film 135 (35mm)
United Kingdom
Scanner
Input Type
Grayscale Depth
Grayscale Depth (External)
Colour Depth
48-bit colour
Colour Depth (External)
48-bit colour
Optical Resolution
7200 dpi x 7200 dpi
Scan Mode
Single-pass
Scan Element Type
CCD
Bulb / Light Source Type
LED
Scan Density Range
3.6D
Scanner Speed Details
8 sec/scan - film (negatives) - preview - 35mm , 8 sec/scan - film (positives) - preview - 35mm , 36 sec/scan - film (negatives) - final - 3600 dpi , 113 sec/scan - film (negatives) - final - 7200 dpi
Scanner Features
Multi-Sampling, hardware Multi-Exposure for negative film, iSRD (Infrared Smart Removal of Defect)
TWAIN
Media Handling
Max Document Size
36.8 mm x 25.4 mm
Slides, film
USB 2.0 - Type B
ENERGY STAR Certified
External power adapter
Software Included
Plustek Quick Scan, SilverFast Ai Studio 8
System Requirements Details
Windows XP/Vista/7/8 - Pentium - 2 GHz - RAM 2 GB - HD 10 GB , MacOS X 10.5 or later - Pentium - 2 GHz - RAM 2 GB - HD 10 GB
12 cm
27.2 cm
11.9 cm
1.6 kg
Interface: USB 2.0
Compatibility: Mac
Compatibility: PC
Brand: Plustek
Price Range Ex VAT: 150 - 300
