Plantronics Voyager Legend Wireless Bluetooth (3.0) Headset
Quicklinx: 8H1ZWS00 Mfr#: 87300-05
Recommended Use: Portable electronics
Connectivity: Wireless
Earcover : Monaural
£55.32 ex VAT
£66.38 inc VAT
Voyager Legend™ - Our best ever Bluetooth® headset
Introducing Plantronics Voyager Legend™, the newest headset in the Voyager family to deliver unsurpassed audio clarity and all-day comfort for the longest of calls. Combining triple-mics that cancel noise and wind, and Smart Sensor™ technology, Voyager Legend understands how and when you want to talk. Sensors react when you put the headset on, letting you quickly take a call without a click. If you're already wearing it, Voyager Legend announces who's calling and waits for you to say "Answer" or "Ignore". Simply check the on-screen battery meter on your iPhone or Android™ smartphone. With technology this advanced, Voyager Legend is the first truly intelligent Bluetooth® headset.
Simply intuitive
Smart Sensor technology reacts when you put the headset on, letting you quickly take a call without a click. If you're already wearing it, Voyager Legend announces who's calling and waits for you to say "Answer" or "Ignore." Simply tap the voice command button and ask to check battery level, connection status, and more. With technology this nimble, Voyager Legend is the first truly intelligent Bluetooth® headset.
Smart Call Routing
Intuitively directs calls to your phone or headset, pauses music for incoming calls, and allows you to automatically answer by simply placing the headset on your ear.
Precision Audio
Multi-microphones optimize your voice and minimize noise caused by wind, movement, and background sounds.
Caller Announce & Voice Commands
Announces incoming caller's name and lets you say "answer" to accept the call or "ignore" to decline. Just say "answer" to take a call. Tap the voice button to check battery level, connection status, or dial Vocalyst to hear emails, newsfeeds, and more.
Moisture Protection
You can rely on the Voyager Legend to work as hard as you do, through rain, sweat and the inevitable coffee spill. Voyager Legend headsets are protected against sweat and moisture damage by P2i technology. The nano-coating is applied during the manufacturing process, resulting in invisible liquid repellent properties that also makes the headset more reliable, wherever your busy life takes you.
Find MyHeadset™ app for Android™ helps locate your headset
Send a tone to hear headset nearby or track last usage on a map using BackTrack™ feature. If you have Android™ OS 3.0 or later, you can view an on-screen headset battery meter in the notification bar.
MyHeadset Updater
Change language, sensor, and other settings on your headset using your USB cable, laptop, and the easy Plantronics MyHeadset Updater online tool
Key features
Sensors transfer and auto-answer calls
Multi mics cancel wind and background noise
Say "Answer" to take a call
Announces incoming caller's name (PBAP)
Convenient, dedicated controls
Magnetic, snap-fit connection makes charging quick and easy.
Check your headset's battery level from your iPhone or use our apps to show meter on your Android™.
Balanced, light, comfortable design
Update your headset language for voice control and more
Discreet car charger
  • Voyager Legend Bluetooth headset
    Simply intuitive. Smart Sensor technology reacts when you put the headset on, letting you quickly take a call without a click. If you're already wearing it, Voyager Legend announces who's calling and waits for you to say "answer" or "ignore. " Simply tap the voice command button and ask to check battery level, connection status, and more. With technology this nimble, Voyager Legend is the first truly intelligent Bluetooth headset.
  • Moisture protection
Poly Voyager Legend - headset
Headset - Bluetooth - wireless
Recommended Use
Headphones Form Factor
In-ear - over-the-ear mount
Wireless
Wireless Technology
Bluetooth
Headphones Technology
Dynamic
Bluetooth Version
Bluetooth 3.0
Sound Output Mode
Mono
Microphone
Boom
Microphone Operation Mode
Mono
Controls
Answer/end
18 g
Recommended Use
Audio Output
Dynamic
Wireless
Wireless Technology
Bluetooth
Bluetooth Version
Bluetooth 3.0
Bluetooth Profiles
Hands-Free Profile (HFP), Headset Profile (HSP), Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP)
Sound Output Mode
Mono
Microphone
Boom
Mono
Remote Control
Controls
Answer/end
Connector Type
Bluetooth
Ear tips kit, USB car charger
Cable Details
USB cable
Power adapter - external
1 x headset battery rechargeable - lithium polymer
Included Qty
1
Run Time (Up To)
7 hours
Standby Time
264 hours
Earcover : Monaural
Brand: Plantronics
Price Range Ex VAT: 50 - 100
