Poly Plantronics Voyager Legend Bluetooth Headset with Charging Case
Quicklinx: 9BWDWS00 Mfr#: 89880-05
Simply intuitive. Smart Sensor technology reacts when you put the headset on, letting you quickly take a call without a click. If you're already wearing it, Voyager Legend announces who's calling and waits for you to say "answer" or "ignore". Simply tap the voice command button and ask to check battery level, connection status, and more. With technology this nimble, Voyager Legend is the first truly intelligent Bluetooth headset.
  • Voyager Legend Bluetooth headset
    Simply intuitive. Smart Sensor technology reacts when you put the headset on, letting you quickly take a call without a click. If you're already wearing it, Voyager Legend announces who's calling and waits for you to say "answer" or "ignore. " Simply tap the voice command button and ask to check battery level, connection status, and more. With technology this nimble, Voyager Legend is the first truly intelligent Bluetooth headset.
  • Moisture protection
    You can rely on the Voyager Legend to work as hard as you do, through rain, sweat and the inevitable coffee spill. Voyager Legend headsets are protected against sweat and moisture damage by P2i technology. The nano-coating is applied during the manufacturing process, resulting in invisible liquid repellent properties that also makes the headset more reliable, wherever your busy life takes you.
Poly Voyager Legend - headset - with Charge Case
Headset - Bluetooth - wireless
Recommended Use
Portable electronics
Headphones Form Factor
In-ear - over-the-ear mount - monaural
Wireless
Wireless Technology
Bluetooth
Bluetooth Version
Bluetooth 3.0
Sound Output Mode
Mono
Microphone
Boom
Microphone Operation Mode
Mono
Controls
Answer/end
Bundled with
Charge Case
18 g
Recommended Use
Bundled with
Charge Case
Audio Output
Wireless
Wireless Technology
Bluetooth
Bluetooth Version
Bluetooth 3.0
Bluetooth Profiles
Hands-Free Profile (HFP), Headset Profile (HSP), Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP), Phonebook Access Profile (PBAP), Secure Simple Pairing (SSP)
Sound Output Mode
Mono
Equaliser
20 bands
Microphone
Boom
Mono
Remote Control
Controls
Answer/end
Ear tips kit
Cable Details
USB charge cable
Power adapter - external
1 x headset battery rechargeable - lithium polymer
Included Qty
1
Run Time (Up To)
7 hours
Standby Time
264 hours
