Product
Plantronics Voyager Focus UC B825 Stereo Headset Only No Base (PC + Bluetooth)
Quicklinx: BMZLWS00 Mfr#: 202652-03
Recommended Use: Computer, Portable electronics
Connectivity: Wireless
More than 50 in stock
£142.88 ex VAT
£171.45 inc VAT
Keep the focus on your conversation, not background noise, with the sophisticated noise canceling and immersive stereo sound of the Plantronics Voyager Focus UC Stereo Bluetooth headset.
UC Standard version built for UC applications and softphones from Avaya, Cisco, Skype and more.
  • Work and entertainment that move with you
    Offering seamless connectivity to your PC or smartphone, and integration with leading UC applications, the Voyager Focus UC is ready to work how you do. With up to 150 feet of wireless range, enjoy mobility while calls and music stay crystal clear, whether you're at your desk, in the conference room, or in the kitchen. Enjoy freedom with no loss of fidelity.
  • You're not just on the call, you're in it
    Make it your business to hear and be heard. The groundbreaking active and passive noise canceling and immersive stereo of the Voyager Focus UC headset enable you to concentrate on your calls or your music without distractions. With three precision-tuned mics and sophisticated muting options, your callers can concentrate on you too. And when you need to pay attention to what's going on around you, just press the OpenMic button to focus on your surroundings.
  • Worry-free mute, a headset that can take a hint
    Control your conversations with intuitive mute capabilities and built-in smart sensors. Easily mute/unmute with the touch of a button, or simply by taking the headset off and putting it back on. Music pauses automatically when a call comes in. You always know whether you're on mute - just glance at the screen or check the USB adapter. If you try to talk while your mic is muted, the Dynamic Mute Alert will give you an audible reminder.
  • Why whistle while you work when you can rock
    When it's time to crank up your music, the Voyager UC delivers rich bass, crisp highs, and natural midtones in superior stereo. And it can take a cue - it pauses the music whenever you take the headset off, and resumes play when you put it back on. Plus, it can tell which way you're wearing it - thanks to the smart mic boom, the stereo, volume and track controls adjust automatically.
Plantronics Voyager Focus UC B825 - no charging stand - headset - UC Standard version
Headset - Bluetooth - wireless
Recommended Use
Portable electronics, computer
Additional Functions
DSP
Headphones Form Factor
On-ear
Wireless
Wireless Technology
Bluetooth
Bluetooth Version
Bluetooth 4.1
Sound Output Mode
Stereo
Active Noise Canceling
Microphone
Boom
Microphone Operation Mode
Mono
Controls
Volume
2 years warranty
Headset - Bluetooth
DSP
155 g
Recommended Use
Max Operating Distance
30 m
Headphones
Supraaural
Wireless
Wireless Technology
Bluetooth
Bluetooth Version
Bluetooth 4.1
Bluetooth Profiles
Advanced Audio Distribution Profile (A2DP)
Sound Output Mode
Stereo
Microphone
Boom
Mono
Remote Control
Controls
Volume
Wireless Link
Transmission Range
45 m
Connector Type
USB
Charging cable
Carrying case, Bluetooth USB adapter
Headset battery rechargeable
Run Time (Up To)
15 hour(s)
Recommended Use: Portable electronics
Brand: Plantronics
Price Range Ex VAT: 100 - 150
