Poly Plantronics Voyager EDGE UC (B255) Bluetooth UC Headset Mobile & PC (UC Variant)
MANAGE CALLS FROM YOUR SMARTPHONE AND PC OR TABLET SIMULTANEOUSLY!
Quicklinx: B796WS00 Mfr#: 202310-02
The sophisticated, performance driven Plantronics Voyager Edge Bluetooth headset is an inspired blend of elegance, comfort, and signature Plantronics audio technology. Voice commands and smartphone assistant integration keep you in control, audio alerts keep you informed, premium noise canceling keeps calls clear in any environment, and a portable charging case keeps Voyager Edge ready when you are.
  • Charges on the go
    Thanks to the included charging case, you'll add up to 10 more hours of talk time to your Voyager Edge for up to a total of 16 hours of talk time. It's easy to check the battery level of your headset or case - just swipe your finger over the icons on the case to see the status indicator.
  • Eliminates disruptive noise
    With three precisely tuned microphones and enhanced noise canceling, the Voyager Edge will optimize your voice and minimize noise caused by wind, movement, and background sounds so your caller hears you, not your surroundings. Additionally, this headset supports wideband audio, making it compatible with smartphones enabled for HD Voice.
  • Responds to your needs
    The Voyager Edge includes responsive smart sensor technology that can redirect calls to your phone or headset, pause music for incoming calls, and automatically answer calls as you place the headset on your ear. It also syncs to your contacts so you can hear who's calling without having to look at your smartphone. Voice commands make call management easy - simply say "Answer" to take the call, or "Ignore" to send it to voicemail.
  • Moisture-resistant
    You can rely on the Voyager Edge to work as hard as you do, through rainy days and the inevitable coffee spill. Protected against moisture damage by P2i technology, the nano-coating is applied during the manufacturing process, resulting in invisible liquid repellent properties that makes the headset more reliable, wherever your busy life takes you.
Poly Voyager Edge UC B255 - headset
Headset - Bluetooth - wireless
Recommended Use
Portable electronics, computer
Headphones Form Factor
Ear-bud
Wireless
Wireless Technology
Bluetooth
Bluetooth Version
Bluetooth 4.0
Sound Output Mode
Mono
Microphone
Boom
Controls
On/off
9 g
Recommended Use
Max Operating Distance
10 m
Audio Output
Ear-bud
Wireless
Wireless Technology
Bluetooth
Bluetooth Version
Bluetooth 4.0
Bluetooth Profiles
Hands-Free Profile (HFP), Advanced Audio Distribution Profile (A2DP)
Sound Output Mode
Mono
Microphone
Boom
Remote Control
Controls
On/off
Wireless Link
Transmission Range
10 m
Connector Type
USB (5 pin Micro-USB Type B)
Bluetooth USB adapter, charging case
Headset battery rechargeable
Run Time (Up To)
6 hour(s)
Standby Time
168 hours
