Poly Plantronics Voyager EDGE Bluetooth Headset - Carbon BLACK
Quicklinx: 9H2TWS00 Mfr#: 201010-05
The sophisticated, performance-driven Plantronics Voyager Edge Bluetooth headset is an inspired blend of elegance, comfort, and signature Plantronics audio technology. Voice commands keep you in control, audio alerts keep you informed, premium noise canceling keeps calls clear in any environment, and a portable charging case keeps Voyager Edge ready when you are.
  • Be ready when your life calls
  • Charges on the go
    Thanks to the included charging case, you'll add up to 10 more hours of talk time to your Voyager Edge for up to a total of 16 hours of talk time. It's easy to check the battery level of your headset or case - just swipe your finger over the icons on the case to see the status indicator.
  • Eliminates distruptive noise
    With three precisely tuned microphones and enhanced noise canceling, the Voyager Edge will optimize your voice and minimize noise caused by wind, movement, and background sounds so your caller hears you, not your surroundings. Additionally, this headset supports wideband audio, making it compatible with smartphones enabled for HD Voice.
  • Responds to your needs
    The Voyager Edge includes responsive smart sensor technology that can redirect calls to your phone or headset, pause music for incoming calls, and automatically answer calls as you place the headset on your ear. It also syncs to your contacts so you can hear who's calling without having to look at your smartphone. Voice commands make call management easy - simply say "Answer" to take the call, or "Ignore" to send it to voicemail.
  • Moisture-resistant
    You can rely on the Voyager Edge to work as hard as you do, through rainy days and the inevitable coffee spill. Protected against moisture damage by P2i technology, the nano-coating is applied during the manufacturing process, resulting in invisible liquid repellent properties that makes the headset more reliable, wherever your busy life takes you.
Poly Voyager Edge - headset
Headset - Bluetooth - wireless - NFC
Recommended Use
Portable electronics
Carbon black
Headphones Form Factor
Ear-bud - over-the-ear mount - monaural
Wireless
Wireless Technology
Bluetooth
Bluetooth Version
Bluetooth 4.0 EDR
Sound Output Mode
Mono
Microphone
Built-in
Controls
Mute, answer/end, play/pause
1-year warranty
9 g
Carbon black
Recommended Use
Protection
Waterproof
Max Operating Distance
10 m
Audio Output
Wireless
Wireless Technology
Bluetooth
Bluetooth Version
Bluetooth 4.0 EDR
Bluetooth Profiles
Hands-Free Profile (HFP), Headset Profile (HSP), Advanced Audio Distribution Profile (A2DP), Phonebook Access Profile (PBAP)
Sound Output Mode
Mono
Remote Control
Controls
Wireless Link
Transmission Range
10 m
Connector Type
USB
Earhook, 2 ear loops, charging case
Cable Details
Micro-USB cable
Power adapter - car - external
Headset battery rechargeable - lithium polymer
Run Time (Up To)
6 hour(s)
Standby Time
168 hours
Limited warranty - 1 year
