Plantronics Voyager 8200UC B8200 Wireless Stereo Headset - Black
Quicklinx: D5KKWS00 Mfr#: 208769-01
Recommended Use: Computer, Portable electronics
Connectivity: Wireless
£201.05 ex VAT
£241.26 inc VAT
Concentrate in comfort
With its contemporary, boomless design and active noise canceling, Voyager 8200 UC blocks out background noise so you can concentrate on your work or your call in comfort and style. Soft ear cushions, 24 hours of listening time and a 3.5 mm audio cable allow you to take calls or play music whether you're in the office, on a flight or on the go. Roam with ease at a range of up to 30 m/98 ft with a Class 1 Bluetooth device.
Immerse yourself in rich audio
Hear music and conversations with complete clarity. All tones, from high to low and everything in between, sound full and natural. Need to tune out distractions? The hi-fi stereo sound and dual-mode active noise canceling cut background noise while the boomless dual-paired microphones keep the focus on your voice.
Stay connected
Need to connect to your computer and mobile phone? No problem. By staying connected to two devices at once, you'll never miss a call. Play music or answer your phone simply by putting on the headset, and pause your media player or mute a call by taking it off. A dedicated button gives you quick access to mute, while voice prompts alert you if you're on mute when you start talking.
Customize your experience
Choose the settings that make your life easier with the Plantronics Hub app for iPhone and Android. Select language preference, feature settings, call, and mute notifications. Keep your device updated with Plantronics Hub over-the-air firmware updates.
Seamless IT management
Plantronics Manager Pro, when used with Plantronics-supported devices such as Voyager 8200 UC, is software-as-a-service that allows IT to manage headset inventory, monitor usage, and maintain devices -- all from a web browser.
  • Boomless design
  • Dual-mode ANC
  • Smart sensory technology
  • Intuitive controls
  • Extended range
  • Plantronics signature audio
  • Dynamic mute alert
  • Multi-device connectivity
  • BT600 USB Bluetooth adaptor
  • Extended battery life
  • OpenMic
  • Concentrate in comfort
  • Immerse yourself in rich audio
  • Boomless design
    Features dual-paired omni-directional microphones and enhanced noise canceling.
  • Dual-mode ANC
    Select the most comfortable active noise canceling (ANC) setting for your environment.
    Dynamic Mute Alert senses and alerts you when you talk when muted
  • Smart sensors
    Smart sensor technology uses contextual intelligence to keep up with you.
  • Stay connected
Poly Voyager 8200 UC - headphones with mic
Headphones - Bluetooth - wireless - NFC - 3.5 mm jack
Recommended Use
Portable electronics, computer
Additional Functions
DSP
Worldwide
Headphones Form Factor
Full size
Wireless
Wireless Technology
Bluetooth
Bluetooth Version
Bluetooth 4.1
Sound Output Mode
Stereo
Active Noise Canceling
Microphone Active Noise Cancelling
Microphones Included
4
Controls
Mute, volume control, on/off, answer/end, next/previous track, reject call, redial
Intelligent Assistant
Siri, Cortana, Google Now
DSP
18 cm
7.6 cm
19 cm
289 g
Recommended Use
Max Operating Distance
30 m
Worldwide
Headphones
Full size
Wireless
Wireless Technology
Bluetooth
Bluetooth Version
Bluetooth 4.1
Bluetooth Profiles
Hands-Free Profile (HFP), Headset Profile (HSP), Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP)
Sound Output Mode
Stereo
Diaphragm
40 mm
Simultaneously Connectable Devices Qty
2
Volume Limiting Function
Microphone
Built-in
4
Remote Control
Controls
Wireless Link
Transmission Range
30 m
Connector Type
Headphones (mini-phone stereo 3.5 mm 4-pole)
Internet of Things (IoT)
Intelligent Assistant Compatible
Headphones cable - detachable
Carrying pouch, Bluetooth USB adapter, USB charge cable
Headphone battery rechargeable - Lithium Ion
660 mAh
Run Time (Up To)
24 hour(s)
Run Time Details
Continuous playback: up to 24 hrs , Continuous talk: up to 20 hrs
Recharge Time
150 min
Recommended Use: Portable electronics
Brand: Plantronics
Price Range Ex VAT: 150 - 300
