Product
Plantronics Voyager 5200 UC Bluetooth Noise Cancelling Wireless Headset - Mobile / PC / Tablet
Quicklinx: C7BNWS00 Mfr#: 206110-01
Be ready to take the call, wherever you’re connected. The Voyager 5200 UC Bluetooth headset offers our most advanced, adaptive noise cancelling with WindSmart technology to reduce disruptive noise. It’s ready to work.
Leave the noise behind
Not in the office? Not a problem. Four adaptive microphones and WindSmart® technology work together to eliminate disruptive background noise, wherever you are. Your voice sounds clear and professional as you seamlessly transition between environments, inside or out. Now you can focus on what you’re saying—not where you’re saying it.
Control by command
Stay in control. Make the Voyager 5200 UC an extension of your mobile life. With one touch, the headset connects with Siri, Google Now, or Cortana so you can call phone contacts, send messages, schedule meetings, or even search the web - all via voice. Plus, voice alerts give talk time updates and even announce incoming callers. Simply say "Answer" or "Ignore" to manage calls without lifting a finger.
Comfort that lasts
The comfort-tested ergonomic design of the Voyager 5200 UC feels as good at the end of the day as it does at the start. The ergonomic earpiece is designed to feel like it’s barely there. It’s a comfortable, powerful tool for all-day productivity.
Never worry about mute again
Simply press the dedicated mute button to switch mute on and off easily. The headset’s dynamic mute alert tells you immediately if you’re speaking while muted. Plus, timed voice alerts continually remind you when mute is still on. Combine that with desktop notifications and a visual mute indictor on the BT600 Bluetooth USB adapter, and you’ll never have to worry about an "oops" moment on an important call.
The power of confidence
Wherever work and life take you, be ready to talk as long as you need with the included portable charging case with integrated docking stand. Completely charge your headset up to two full times, so you’re always ready to talk.
Optimized for your UC application
Certified for Skype for Business and Optimized for Microsoft® Lync®. Built for UC applications and softphones from Avaya, Cisco and others* *Requires Plantronics Hub.
Plantronics Voyager 5200 UC - headset
Headset - Bluetooth - wireless
Recommended Use
Computer
Additional Functions
DSP
Europe
Headphones Form Factor
Ear-bud - over-the-ear mount
Wireless
Wireless Technology
Bluetooth
Sound Output Mode
Mono
Microphone
Boom
Microphone Active Noise Cancelling
Controls
Volume, mute button
Headset - Bluetooth
DSP
Recommended Use
Computer
Protection
Moisture-resistant, wind protection
Europe
Headphones
Wireless
Wireless Technology
Bluetooth
Available Microphone
Sound Output Mode
Mono
Microphone
Boom
Remote Control
Controls
Volume, mute button
Carrying case, Bluetooth USB adapter
Headset battery rechargeable
Run Time (Up To)
7 hour(s)
