Raise the power of your voice. A dedicated voice control button easily activates Siri, Google Now, or Cortana. Whispered alerts update you on talk time, and even announce the names of incoming callers so you can simply say "Answer" or "Ignore" to calls without lifting a finger.
From bustling city streets to the corner café, some of life's most important calls happen in the most unexpected places. The noise canceling and six layers of WindSmart technology eliminate disruptive background noise like wind and chatter so your voice sounds clear, indoors and out.
Voice Control
Reliable Clarity
Adaptive Microphones
Work together to reduce disruptive background noise.
Smart Sensors
Smart sensor technology uses contextual intelligence to keep up with you.
Sweatproof Nano-Coating
Protected against light rain, humidity, and sweat.
Windsmart Technology
Detects wind direction and responds accordingly.
Software-Enabled Functionality
Use Plantronics Hub mobile app to locate your lost headset, change languages, wirelessly update firmware, or personalize settings and alerts. Use Plantronics Hub desktop software to view headset battery meter, change languages, update firmware, enable softphone call control, or personalize settings and alerts.
Voice control
Raise the power of your voice. A dedicated voice control button easily activates Siri, Google Now, or Cortana. Whispered alerts update you on talk time, and even announce the names of incoming callers so you can simply say "Answer" or "Ignore" to calls without lifting a finger. -
Reliable clarity
From bustling city streets to the corner café, some of life's most important calls happen in the most unexpected places. The noise canceling and six layers of WindSmart technology eliminate disruptive background noise like wind and chatter so your voice sounds clear, indoors and out. -
Adaptive microphones
Work together to reduce disruptive background noise. -
Smart sensors
Smart sensor technology uses contextual intelligence to keep up with you. -
Sweatproof nano-coating
Protected against light rain, humidity, and sweat. -
Windsmart technology
Detects wind direction and responds accordingly. -
Software-enabled functionality
- Poly Voyager 5200 - headset
- Product Type
- Headset - Bluetooth - wireless
- Compatibility
- iPhone, iPad, iPod, Android phone
- Recommended Use
- Portable electronics
- Additional Functions
- DSP
- Localisation
- Europe
- Headphones Form Factor
- Ear-bud - over-the-ear mount
- Connectivity Technology
- Wireless
- Wireless Technology
- Bluetooth
- Bluetooth Version
- Bluetooth 4.1
- Sound Output Mode
- Mono
- Microphone
- Boom
- Microphone Noise Cancelling
- Controls
- Volume, mute button
- 2-year warranty
- Product Type
- Compatibility
- DSP
- 20 g
- Recommended Use
- Voice alerts
- Protection
- Moisture-resistant, sweat-resistant, wind protection
- Max Operating Distance
- 30 m
- Localisation
- Europe
Audio Output
- Wireless
- Bluetooth
- Bluetooth Version
- Bluetooth 4.1
- Bluetooth Profiles
- Hands-Free Profile (HFP), Headset Profile (HSP), Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP), Phonebook Access Profile (PBAP)
- Sound Output Mode
- Mono
- Equaliser
- 20 bands
- Voice control
Microphone
- Boom
- Noise Cancelling
Remote Control
- Controls
- Included Accessories
- USB charge cable
- Battery
- Headset battery rechargeable - Lithium Ion
- Run Time (Up To)
- 7 hour(s)
- Recharge Time
- 1.5 hour(s)
- Limited warranty - 2 years
