Plantronics Voyager 5200 (consumer)
Quicklinx: CM6LWS00 Mfr#: 203500-05
Recommended Use: Portable electronics
Connectivity: Wireless
42 in stock
£114.58 ex VAT
£137.49 inc VAT
Raise the power of your voice. A dedicated voice control button easily activates Siri, Google Now, or Cortana. Whispered alerts update you on talk time, and even announce the names of incoming callers so you can simply say "Answer" or "Ignore" to calls without lifting a finger.
From bustling city streets to the corner café, some of life's most important calls happen in the most unexpected places. The noise canceling and six layers of WindSmart technology eliminate disruptive background noise like wind and chatter so your voice sounds clear, indoors and out.
Voice Control
Reliable Clarity
Adaptive Microphones
Work together to reduce disruptive background noise.
Smart Sensors
Smart sensor technology uses contextual intelligence to keep up with you.
Sweatproof Nano-Coating
Protected against light rain, humidity, and sweat.
Windsmart Technology
Detects wind direction and responds accordingly.
Software-Enabled Functionality
Use Plantronics Hub mobile app to locate your lost headset, change languages, wirelessly update firmware, or personalize settings and alerts. Use Plantronics Hub desktop software to view headset battery meter, change languages, update firmware, enable softphone call control, or personalize settings and alerts.
  • Voice control
  • Reliable clarity
  • Adaptive microphones
  • Smart sensors
  • Sweatproof nano-coating
  • Windsmart technology
  • Software-enabled functionality
Poly Voyager 5200 - headset
Headset - Bluetooth - wireless
Compatibility
iPhone, iPad, iPod, Android phone
Recommended Use
Additional Functions
DSP
Europe
Headphones Form Factor
Ear-bud - over-the-ear mount
Wireless
Wireless Technology
Bluetooth
Bluetooth Version
Bluetooth 4.1
Sound Output Mode
Mono
Microphone
Boom
Microphone Active Noise Cancelling
Controls
Volume, mute button
TCO Certified
TCO Certified Headsets 3
Compatibility
DSP
20 g
Recommended Use
Protection
Moisture-resistant, sweat-resistant, wind protection
Max Operating Distance
30 m
Europe
Headphones
Wireless
Wireless Technology
Bluetooth
Bluetooth Version
Bluetooth 4.1
Bluetooth Profiles
Hands-Free Profile (HFP), Headset Profile (HSP), Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP), Phonebook Access Profile (PBAP)
Sound Output Mode
Mono
Equaliser
20 bands
Voice control, voice alerts
Microphone
Boom
Remote Control
Controls
Volume, mute button
USB charge cable
TCO Certified
Headset battery rechargeable - Lithium Ion
Run Time (Up To)
7 hour(s)
Recharge Time
1.5 hour(s)
Brand: Plantronics
Price Range Ex VAT: 100 - 150
