The world is your office. But it doesn't have to look that way. Sleek and discreet, Voyager 3200 UC cancels the noise and keeps the conversation going. Anytime, anywhere.
Comfort without compromise
Quickly put your Voyager 3200 UC headset on to take a call and take it off just as easily when you're done. The sleek, in-ear design and three sizes of silicone eartips ensure a discreet and comfortable fit every time. -
Superior sound quality
With three precisely tuned microphones and enhanced noise-canceling technology, Voyager 3200 UC separates your voice from disruptive background sounds so your caller hears what you're saying, not where you're saying it. Plus, support for wideband audio ensures compatibility with HD Voice-enabled smartphones. -
Responsive and intuitive
Put the headset on, and smart sensors automatically know to answer the call. Press the dedicated mute button to easily switch mute on and off. The headset's dynamic mute alert tells you immediately if you're speaking while muted. Plus, with the touch of a button you can activate Siri, Cortana, or Google Now. -
Mobile confidence
Wherever the day takes you, the convenient portable charge case with universal docking ensures you're always ready to talk. A single charge gives you long hours of additional talk time. Plus, there's room to store your BT600 Bluetooth adapter when not in use.
- Poly Voyager 3200 UC - headset
- Product Type
- Headset - Bluetooth - wireless
- Compatibility
- iPhone, Android phone, Mac, Windows
- Recommended Use
- Portable electronics, computer
- Additional Functions
- DSP
- Headphones Form Factor
- Ear-bud
- Connectivity Technology
- Wireless
- Wireless Technology
- Bluetooth
- Bluetooth Version
- Bluetooth 4.1
- Sound Output Mode
- Mono
- Microphone
- Boom
- Microphone Noise Cancelling
- Controls
- Volume, mute button, answer/end
- Product Type
- Compatibility
- DSP
- 9 g
- Recommended Use
- Voice alerts
- Max Operating Distance
- 30 m
Audio Output
- Ear-bud
- Wireless
- Bluetooth
- Bluetooth Version
- Bluetooth 4.1
- Bluetooth Profiles
- Advanced Audio Distribution Profile (A2DP)
- Sound Output Mode
- Mono
Microphone
- Boom
- Noise Cancelling
Remote Control
- Controls
Wireless Link
- Transmission Range
- 30 m
- Included Accessories
- Bluetooth USB adapter, charging case
- Battery
- Headset battery rechargeable - Lithium Ion
- Capacity
- 93 mAh
- Run Time (Up To)
- 6 hour(s)
- Standby Time
- 168 hours
