Plantronics Voyager 3200 UC
Quicklinx: DBN5WS00 Mfr#: 207371-01
Recommended Use: Computer, Portable electronics
Connectivity: Wireless
More than 50 in stock
£134.44 ex VAT
£161.32 inc VAT
The world is your office. But it doesn't have to look that way. Sleek and discreet, Voyager 3200 UC cancels the noise and keeps the conversation going. Anytime, anywhere.
  • Comfort without compromise
    Quickly put your Voyager 3200 UC headset on to take a call and take it off just as easily when you're done. The sleek, in-ear design and three sizes of silicone eartips ensure a discreet and comfortable fit every time.
  • Superior sound quality
    With three precisely tuned microphones and enhanced noise-canceling technology, Voyager 3200 UC separates your voice from disruptive background sounds so your caller hears what you're saying, not where you're saying it. Plus, support for wideband audio ensures compatibility with HD Voice-enabled smartphones.
  • Responsive and intuitive
    Put the headset on, and smart sensors automatically know to answer the call. Press the dedicated mute button to easily switch mute on and off. The headset's dynamic mute alert tells you immediately if you're speaking while muted. Plus, with the touch of a button you can activate Siri, Cortana, or Google Now.
  • Mobile confidence
    Wherever the day takes you, the convenient portable charge case with universal docking ensures you're always ready to talk. A single charge gives you long hours of additional talk time. Plus, there's room to store your BT600 Bluetooth adapter when not in use.
Poly Voyager 3200 UC - headset
Headset - Bluetooth - wireless
Compatibility
iPhone, Android phone, Mac, Windows
Recommended Use
Portable electronics, computer
Additional Functions
DSP
Headphones Form Factor
Ear-bud
Wireless
Wireless Technology
Bluetooth
Bluetooth Version
Bluetooth 4.1
Sound Output Mode
Mono
Microphone
Boom
Microphone Active Noise Cancelling
Controls
Volume, mute button, answer/end
TCO Certified
TCO Certified Headsets 3
Compatibility
DSP
9 g
Recommended Use
Max Operating Distance
30 m
Headphones
Ear-bud
Wireless
Wireless Technology
Bluetooth
Bluetooth Version
Bluetooth 4.1
Bluetooth Profiles
Advanced Audio Distribution Profile (A2DP)
Sound Output Mode
Mono
Voice alerts
Microphone
Boom
Remote Control
Controls
Wireless Link
Transmission Range
30 m
Bluetooth USB adapter, charging case
TCO Certified
Headset battery rechargeable - Lithium Ion
93 mAh
Run Time (Up To)
6 hour(s)
Standby Time
168 hours
Recommended Use: Portable electronics
Brand: Plantronics
Price Range Ex VAT: 100 - 150
