Plantronics Voice Tube Tristar Encore Supra Duo x1
Quicklinx: CSF6WS00 Mfr#: 29960-01
Stock Status: Used Stock
£1.27 ex VAT
£1.52 inc VAT
Plantronics offers products for the computer and mobile market segments, specializing in telephone products, such as amplified telephone headsets, telephones for hearing-impaired users and noise-canceling headsets, handsets for use in high-noise environments and value packs. As the world's leading designer, manufacturer and marketer of lightweight communications headset products, Plantronics produces a great deal of accessories for its versatile headsets.
One replacement voice tube for Encore, Tristar, and SupraPlus series. Clear color.
Poly - voice tube for headset
Voice tube
Intended For
Headset
Clear
DuoPro; DuoSet; Encore; TriStar
Voice tube
Intended For
Headset
Clear
Poly - Plantronics DuoPro , Poly - Plantronics DuoSet , Poly - Plantronics Encore , Poly - Plantronics TriStar
Used stock
What is used stock?
Accessories Packaging Functional Software Manuals
Ref: CSF6 041125
Condition: This item is new and unused. The packaging has been opened.
This part of the stock item is not applicable e.g. it might not include accessories or software as standard  This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.  This part of the stock item is present and in good condition  This part of the stock item is not applicable e.g. it might not include accessories or software as standard  This part of the stock item is not applicable e.g. it might not include accessories or software as standard  £0.15
Legend
  • This part of the stock item is present and in good conditionThis part of the stock item is present and in good condition
  • This part of the stock item is not present or functionalThis part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standardThis part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.This item has not been tested.
Brand: Plantronics
Price Range Ex VAT: 0 - 50
