Today's enterprise and contact center professionals work across a range of devices - from PC to mobile to desk phone. The Savi 8200 Series headset system makes call management effortless with three-way connectivity that lets you switch seamlessly between all of them.
The sound of excellence
Savi 8200 Series delivers enterprise-grade audio for a premium listening experience. -
Connect and communicate more effectively
The Savi 8200 Series headset system helps you achieve peak performance and productivity with a range of communication features. -
Multi-device connectivity
Switch seamlessly between PC, mobile and desk phone.
- Poly Savi 8200 Series W8220-M - Microsoft - headset
- Product Type
- Headset - DECT / Bluetooth - wireless
- Recommended Use
- Phone, computer
- Localisation
- EMEA
- Headphones Form Factor
- On-ear
- Connectivity Technology
- Wireless
- Wireless Technology
- DECT / Bluetooth
- Bluetooth Version
- Bluetooth 4.2
- Sound Output Mode
- Stereo
- Audio Specifications
- Frequency Response 20 - 20000 Hz - Sensitivity 118 dB
- Impedance
- 32 Ohm
- Active Noise Canceling
- Microphone
- Boom
- Controls
- Mute, volume, on/off, answer/end
- Product Type
- 160 g
- Recommended Use
- Phone, computer
- Max Operating Distance
- 180 m
- Localisation
- EMEA
Headphones
- On-ear
- Wireless
- DECT / Bluetooth
- Bluetooth Version
- Bluetooth 4.2
- Bluetooth Profiles
- Hands-Free Profile (HFP), Headset Profile (HSP), Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP)
- Sound Output Mode
- Stereo
- 20 - 20000 Hz
- Sensitivity
- 118 dB
- Impedance
- 32 Ohm
- Diaphragm
- 32 mm
Microphone
- Boom
- 100 - 6800 Hz
- Max Sound Pressure
- 112 dB
Remote Control
- Controls
- Cables Included
- USB cable , Phone cable , USB-C cable
- Included Accessories
- Base station, charging cradle, power supply unit
- Battery
- Headset battery rechargeable - lithium polymer
- Capacity
- 490 mAh
- Run Time (Up To)
- 13 hour(s)
- Standby Time
- 50 hours
- Recharge Time
- 3 hour(s)
