Poly Plantronics Savi W8210-M Mono MS Wireless Headset
Quicklinx: F519WS00 Mfr#: 207322-02
Today's enterprise and contact center professionals work across a range of devices - from PC to mobile to desk phone. The Savi 8200 Series headset system makes call management effortless with three-way connectivity that lets you switch seamlessly between all of them.
  • The sound of excellence
    Savi 8200 Series delivers enterprise-grade audio for a premium listening experience.
  • Connect and communicate more effectively
    The Savi 8200 Series headset system helps you achieve peak performance and productivity with a range of communication features.
  • Multi-device connectivity
    Switch seamlessly between PC, mobile and desk phone.
Poly Savi 8200 Series W8210-M - Microsoft - headset
Headset - DECT / Bluetooth - wireless
Recommended Use
Phone, computer
EMEA
Headphones Form Factor
On-ear
Wireless
Wireless Technology
DECT / Bluetooth
Bluetooth Version
Bluetooth 4.2
Sound Output Mode
Mono
Audio Specifications
Frequency Response 20 - 20000 Hz - Sensitivity 118 dB
Impedance
32 Ohm
Active Noise Canceling
Microphone
Boom
Controls
Mute, volume, on/off, answer/end
Software Certification
Certified for Microsoft Teams
115 g
Recommended Use
Phone, computer
Max Operating Distance
180 m
EMEA
Audio Output
On-ear
Wireless
Wireless Technology
DECT / Bluetooth
Bluetooth Version
Bluetooth 4.2
Bluetooth Profiles
Hands-Free Profile (HFP), Headset Profile (HSP), Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP)
Sound Output Mode
Mono
Frequency Response
20 - 20000 Hz
Sensitivity
118 dB
Impedance
32 Ohm
Diaphragm
32 mm
Microphone
Boom
Frequency Response
100 - 6800 Hz
Max Sound Pressure
112 dB
Remote Control
Controls
Base station, charging cradle, power supply unit
Cable Details
USB cable , Phone cable , USB-C cable
Headset battery rechargeable - lithium polymer
490 mAh
Run Time (Up To)
13 hour(s)
Standby Time
50 hours
Recharge Time
3 hour(s)
