Poly Plantronics Savi 8200 Mono MS Wireless Headset
Quicklinx: F4CWWS00 Mfr#: 207309-12
Recommended Use: Phone, Computer, Phone
Connectivity: Wireless
Earcover : Monaural
£247.78 ex VAT
£297.33 inc VAT
Enjoy simply better conversations with the Savi 8200 Series. Effortlessly manage PC, mobile and desk phone calls, with enterprise-grade DECT audio.
  • One headset for all your devices
    Today's enterprise and contact center professionals work across a range of devices - from PC to mobile to desk phone. The Savi 8200 Series headset system makes call management effortless with three-way connectivity that lets you switch seamlessly between all of them. Conference two of your three devices to collaborate with colleagues or connect up to four Savi 8200 Series headsets for training or call resolution.
  • Connect and communicate more effectively
    The Savi 8200 Series headset system helps you achieve peak performance and productivity with a range of communication features. Enterprise-grade DECT audio allows you to roam or multi-task up to 590 ft/180 m from your PC. One-touch controls - such as call answer/end, volume up/down and mute - let you manage calls from any connected device within roaming range. Convenient voice prompts notify you of mute status, roaming range limit, and more.
Poly Savi 8200 Series W8210/A - headset
Headset - DECT / Bluetooth - wireless
Recommended Use
Phone, computer
EMEA
Headphones Form Factor
On-ear
Wireless
Wireless Technology
DECT / Bluetooth
Bluetooth Version
Bluetooth 4.2
Sound Output Mode
Mono
Audio Specifications
Frequency Response 20 - 20000 Hz - Sensitivity 118 dB
Impedance
32 Ohm
Active Noise Canceling
Microphone
Boom
Controls
Mute, volume, on/off, answer/end
115 g
Recommended Use
Phone, computer
Max Operating Distance
180 m
EMEA
Audio Output
On-ear
Wireless
Wireless Technology
DECT / Bluetooth
Bluetooth Version
Bluetooth 4.2
Bluetooth Profiles
Hands-Free Profile (HFP), Headset Profile (HSP), Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP)
Sound Output Mode
Mono
Frequency Response
20 - 20000 Hz
Sensitivity
118 dB
Impedance
32 Ohm
Diaphragm
32 mm
Microphone
Boom
Frequency Response
100 - 6800 Hz
Max Sound Pressure
112 dB
Remote Control
Controls
Base station, charging cradle, power supply unit
Cable Details
USB cable , Phone cable , USB-C cable
Headset battery rechargeable - lithium polymer
490 mAh
Run Time (Up To)
13 hour(s)
Standby Time
50 hours
Recharge Time
3 hour(s)
Recommended Use: Computer
Earcover : Monaural
Brand: Poly
