Poly Plantronics Rig 500HX Headset
Quicklinx: CKDBWS00 Mfr#: 204805-05#BT
Designed for Xbox One, the RIG 500HX headset delivers performance audio you can count on with durable, lightweight comfort for competitive challenges.
FOCUS WINS
The durable yet lightweight frame lets you configure components for endurance or focus. The included isolating ear cups immerse you in the game, blocking out distracting background noise.
CONFIGURE TO WIN
RIG 500 is designed to let you change out components to match your needs. Opt for immersive, isolating cups to game in peace or choose the open, vented cups to keep your cool during long sessions. The flexible headset frame can be swapped out for translucent or camo color options.
PERFORMANCE AUDIO
Audio fidelity that gives you an edge. Dynamic, 40 mm drivers are matched with low-frequency resonators to boost the bass response without destroying crucial mids and highs. The noise-cancelling boom mic flips up to mute, making it perfect for solo campaigns.
  • Performance audio
    Audio fidelity that gives you an edge. Dynamic, 40 mm drivers are matched with low-frequency resonators to boost the bass response without destroying crucial mids and highs. The noise-canceling boom mic flips up to mute, making it perfect for solo campaigns.
  • Focus wins
  • Configure to win
RIG 500HX - headset
Headset - wired
Recommended Use
Game console
Headphones Form Factor
Full size
Wired
Headphones Technology
Dynamic
Sound Output Mode
Stereo
Audio Specifications
Frequency Response 20 - 20000 Hz - Sensitivity 111 dB
Impedance
32 Ohm
Max Input Power
40 mW
Microphone
Boom
Controls
Microphone on/mute
Xbox One
Headset - wired
Earpad Material
Memory foam
Recommended Use
Game console
Audio Output
Full size
Dynamic
Wired
Sound Output Mode
Stereo
Frequency Response
20 - 20000 Hz
Max Input Power
40 mW
Sensitivity
111 dB
Impedance
32 Ohm
Diaphragm
40 mm
Adjustable Headband
Microphone
Boom
Sensitivity
-45 dBV/Pascal
Frequency Response
100 - 10000 Hz
Signal-To-Noise Ratio
42 dB
Remote Control
Controls
Microphone on/mute
Connector Type
Headset (mini-phone stereo 3.5 mm 4-pole)
Cable Details
Headset cable
Xbox One
