Designed to solve the communications challenges of businesses migrating to unified communications, the MDA200 Headset Communications Hub lets you manage PC voice and multi-media, while maintaining connectivity to your desk phone. Get the most from your desk phone. Make the most of your PC. Even take calls on the mobile when used with a Plantronics Bluetooth USB headset. The MDA200 is plug-and-play and compatible with all major UC applications. No need for extra headsets or firmware headaches. It is rapid-to-deploy for flexible workplaces, hotels, tele-workers, call centers and more. The MDA200 is the simple, seamless way to transition to UC for the enterprise that just can't sit still.
- Poly MDA200 Headset Communications Hub - handset/computer/headset switch for headphones
- Product Type
- Handset/computer/headset switch
- Intended For
- Headphones
- 1-year warranty
- Product Type
- Intended For
- Headphones
- Connections
- USB - 4 PIN USB Type A
- Connection via USB
- 1 year
