Product
Plantronics Leatherette Ear Cushion EncorePro x2
Quicklinx: CGH7WS00 Mfr#: 80355-01
Stock Status: In Stock, Used Stock
£2.49 ex VAT
£2.98 inc VAT
Express delivery Order within the next 9 hours for delivery tomorrow
Plantronics - ear cushion
Ear cushion
Packaged Quantity
2 (specifications are for single item)
Product Material
Leatherette
EncorePro HW291N, HW301N
Packaged Quantity
Ear cushion
Product Material
Leatherette
Plantronics EncorePro HW291N, HW301N
Used stock
What is used stock?
Accessories Packaging Functional Software Manuals
Ref: CGH7 039486
Condition: Customer return - item has been used and shows signs of use
This part of the stock item is not present or functional  This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.  This part of the stock item is present and in good condition  This part of the stock item is not present or functional  This part of the stock item is not present or functional  £0.30
Legend
  • This part of the stock item is present and in good conditionThis part of the stock item is present and in good condition
  • This part of the stock item is not present or functionalThis part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standardThis part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.This item has not been tested.
Brand: Plantronics
Stock Status: Used Stock
Price Range Ex VAT: 0 - 50
