It’s easy to set up and get talking; simply switch on your Explorer 80 and your smartphone can immediately find it for pairing. Choose which language you prefer and you’ll hear important battery and connection status alerts whispered in your ear. Once you’ve made a few calls and listened to location directions, you’ll wonder why you didn’t go hands-free sooner. Don’t worry about missing a word, the Explorer 80 has got you covered. With long hours of talk time on a single charge, you can rely on this headset to keep you connected and ready to make and take calls when you need to. If you forget to turn it off, the DeepSleep hibernation mode will help keep it charged longer. Have a smartphone and a tablet? Connect Explorer 80 to two different Bluetooth audio devices at once and control your music and audio using headset buttons instead of your smartphone in between calls.
Discover wireless freedom
It’s easy to set up and get talking; simply switch on your Explorer 80 and your smartphone can immediately find it for pairing. Choose which language you prefer and you’ll hear important battery and connection status alerts whispered in your ear. Once you’ve made a few calls and listened to location directions, you’ll wonder why you didn’t go hands-free sooner. -
Keep the conversation going
Don’t worry about missing a word, the Explorer 80 has got you covered. With long hours of talk time on a single charge, you can rely on this headset to keep you connected and ready to make and take calls when you need to. If you forget to turn it off, the DeepSleep hibernation mode will help keep it charged longer. -
Control calls, music and media
- Poly - Plantronics Explorer 80 - headset
- Product Type
- Headset - Bluetooth - wireless
- Recommended Use
- Portable electronics
- Onyx black
- Headphones Form Factor
- Ear-bud - over-the-ear mount
- Connectivity Technology
- Wireless
- Wireless Technology
- Bluetooth
- Bluetooth Version
- Bluetooth 3.0
- Sound Output Mode
- Mono
- Controls
- Mute, volume, answer/end, play/pause, next/previous track
- Product Type
- 8.2 g
- Onyx black
- Recommended Use
- Max Operating Distance
- 10 m
Audio Output
- Wireless
- Bluetooth
- Bluetooth Version
- Bluetooth 3.0
- Bluetooth Profiles
- Hands-Free Profile (HFP), Headset Profile (HSP), Secure Simple Pairing (SSP)
- Sound Output Mode
- Mono
Remote Control
- Controls
Wireless Link
- Transmission Range
- 10 m
- Cable Details
- Micro-USB charge cable
- Battery
- Headset battery rechargeable - Lithium Ion
- Run Time (Up To)
- 11 hour(s)
- Standby Time
- 384 hours
- Recharge Time
- 2 hour(s)
