The all-day comfort, reliability, and durability the EncorePro Family is known for, with the addition of built-in call control. The EncorePro 700 USB Series is ready for every call because every call matters.
Clarity, Comfort, Control
The EncorePro 700 USB Series is a fully integrated audio solution that enables users to focus on every conversation with all-day comfort, built-in call control, advanced audio processing and an enhanced noise canceling microphone. The result? An experience that makes every conversation sound natural, enabling the user to focus on what matters most - the conversation.
Luxurious Comfort, Distinctive Design
The top-of-the-line series, featuring exceptional audio quality. Made from high-grade nylon composite materials, with soft leatherette ear cushions, the EncorePro 700 USB Series provides the user with an ultra-lightweight fit for all-day comfort. The unique, extendable boom ensures precise positioning for optimal noise cancellation and voice clarity, staying clear of the user's peripheral vision so that they can focus on other tasks at hand.
Clarity, comfort, control
The EncorePro 700 USB Series is a fully integrated audio solution that enables users to focus on every conversation with all-day comfort, built-in call control, advanced audio processing and an enhanced noise canceling microphone. The result? An experience that makes every conversation sound natural, enabling the user to focus on what matters most - the conversation. -
Luxurious comfort, distinctive design
- Poly EncorePro HW715 - headset
- Product Type
- Headset - wired - USB
- Compatibility
- Mac, Windows
- Recommended Use
- Phone, computer
- Headphones Form Factor
- On-ear
- Connectivity Technology
- Wired
- Sound Output Mode
- Mono
- Microphone
- Boom
- Microphone Operation Mode
- Mono
- Controls
- Mute, volume, answer/end
- Works With Chromebook
- Product Type
- Compatibility
- Mac, Windows
- Recommended Use
- Phone, computer
Audio Output
- On-ear
- Wired
- Sound Output Mode
- Mono
- Adjustable Headband
Microphone
- Boom
- Mono
Remote Control
- Controls
- Connector Type
- Headset (4 PIN USB Type A)
- Cable Details
- Headset cable
