MOBILE TO DESK MADE EASY
Today’s workers need mobile freedom and desktop convenience. The Poly Elara 60 Series gives them the best of both worlds. It’s a desktop mobile phone station that keeps your mobile charged, makes it easy to move a call from your mobile and back again, and lets you join Microsoft Teams meetings with a single touch. Headset and speakerphone options offer customized comfort plus flexibility.
Turn your smartphone into a desktop collaboration tool
The call doesn't end when you get to the office - it gets better. Now you can seamlessly transition the call to the Poly Elara 60 Series mobile phone station and make collaboration happen your way, using headset, speakerphone and handset options. -
Stay connected and charged
Personalize your communications choices with a range of enterprise-grade headset, speakerphone and handset options to manage your mobile calls. And while you're on the call, your Android or iOS smartphone automatically charges with wired or optional multi-coil wireless charging. -
Deployment is simple
With Poly Elara 60 Series, there is no service provisioning and no extra wires. Just plug it into a power outlet, pair your mobile phone and you're done. Deployment throughout the enterprise is easy, saving time and money and enabling greater simplicity and freedom - for you and your users.
- Poly Elara 60 WS - without headset - speakerphone
- Product Type
- Speakerphone - Bluetooth - wireless
- Localisation
- Rest of World
- Connectivity Technology
- Wireless
- Wireless Technology
- Bluetooth
- Bluetooth Version
- Bluetooth 4.2 EDR
- Audio Specifications
- Frequency Response 100 - 6800 Hz - Sensitivity 81.5 dB
- Impedance
- 4 Ohm
- Microphone Operation Mode
- Omni-directional
- Controls
- Mute, volume, answer/end, play/pause, next/previous track
- Software Certification
- Certified for Microsoft Teams
- Product Type
- Series
- 60 Series
- Dimensions & Weight Details
- 650 g
- LCD display, Kensington lock secure slot
- Max Operating Distance
- 9.1 m
- Localisation
- Rest of World
Audio Output
- Wireless
- Bluetooth
- Bluetooth Version
- Bluetooth 4.2 EDR
- Bluetooth Profiles
- Hands-Free Profile (HFP), Headset Profile (HSP), Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP)
- 100 - 6800 Hz
- Sensitivity
- 81.5 dB
- Impedance
- 4 Ohm
- Diaphragm
- 50 mm
Microphone
- Omni-directional
- Sensitivity
- -16 dBV/Pascal
- 100 - 6800 Hz
Remote Control
- Controls
- Included Accessories
- Power adapter
- Voltage Required
- AC 120/230 V
