Poly DW261N/A
Poly DW261N/A
Quicklinx: 6NK3WS00 Mfr#: 39406-01
The SupraPlus Digital Binaural NC Headset has been created to work with the VistaPlus adapter to optimize audio performance in Health and Safety conscious work environments. Meeting the lower sound exposure thresholds required by Noise at Work legislation often means that the headsets receive is quieter than previously experienced. This can make calls harder to hear and potentially reduce productivity. SupraPlus Digital uses on board memory to store the exact parameters characterizing each individual headset. VistaPlus reads these parameters and tunes its setting to optimally match with the headset and lifting the receive level to enhance ease of listening, whilst remaining within the limits set by the New Noise Directive.
SupraPlus Digital can only be used with the VistaPlus adapter offering the highest standards in the market in terms of sound protection and sound clarity. No additional bottom cable purchase is required as it is supplied in the box with the headset.
Poly - Plantronics SupraPlus DIGITAL D261N - headset
Headset - wired
Recommended Use
Phone
Headphones Form Factor
On-ear binaural
Wired
Headphones Technology
Dynamic
Audio Specifications
Frequency Response 100 - 4000 Hz
Impedance
300 Ohm
Microphone
Boom
Microphone Operation Mode
Mono
Headset - wired
Recommended Use
Phone
Audio Output
On-ear binaural
Dynamic
Wired
Frequency Response
100 - 4000 Hz
Impedance
300 Ohm
Microphone
Boom
Mono
Sensitivity
-49 dB
Impedance
1.5 kOhm
Frequency Response
200 - 4000 Hz
Connector Type
Headset (Quick Disconnect)
