Poly DW251/A
Poly DW251/A
Quicklinx: 6NJZWS00 Mfr#: 39403-01
If you are working in an intensive telecoms environment the SupraPlus DIGITAL - in conjunction with VistaPlus - is simply the best solution available, offering sound quality, ultimate protection and comfort. With increasingly stringent Noise at Work legislation, call center managers have to ensure that agents are working within the limits. Meeting those requirements means that headsets often have to be set at lower volumes than before. SupraPlus DIGITAL uses on-board memory to optimize the receive level, while remaining within limits of the new Noise at Work legislation. The SupraPlus DIGITAL headset is based on one of the best-selling headsets, and offers a range of features for all-day wearing comfort and legendary Plantronics audio quality.
Poly - Plantronics SupraPlus DIGITAL D251 - headset
Headset - wired
Recommended Use
Phone
Headphones Form Factor
On-ear monaural
Wired
Headphones Technology
Dynamic
Sound Output Mode
Mono
Audio Specifications
Frequency Response 100 - 4000 Hz
Impedance
150 Ohm
Microphone
Boom
Microphone Operation Mode
Mono
Headset - wired
Recommended Use
Phone
Audio Output
On-ear monaural
Dynamic
Wired
Sound Output Mode
Mono
Frequency Response
100 - 4000 Hz
Impedance
150 Ohm
Microphone
Boom
Mono
Sensitivity
-49 dB
Impedance
1.5 kOhm
Frequency Response
200 - 4000 Hz
Connector Type
Headset (Quick Disconnect)
