The Plantronics Calisto 610 is a corded USB speakerphone for plug-and-play conferencing convenience. The Calisto 610 USB speakerphone turns any PC into a portable conferencing device.
Manage calls - anywhere - with plug-and-play convenience. The compact speakerphone integrates with leading softphones to easily manage calls and set up small informal conferences. Single-touch controls include call answer/end, volume adjust, and mute.
Compatibility with a Kensington style lock feature boosts security when deployed in small/medium work areas and shared conference rooms. With crisp wideband audio and full-duplex 360-degree microphone pick up, enjoy business- quality sound for everyone on the call.
- Plantronics Calisto P610 - speaker phone
- Product Type
- Speaker phone - wired
- Recommended Use
- Computer - communication
- Connectivity Technology
- Wired
- Microphone
- Built-in
- Controls
- Mute, volume, answer/end
- 2 years warranty
- Product Type
- Speaker phone
- Series
- 600 Series
- 11 cm
- 11 cm
- 3.2 cm
- Recommended Use
Headphones
- Wired
Microphone
- Directivity Angle
- 360°
- Audio Input Details
- Omni-directional - 360°
Remote Control
- Controls
- Connector Type
- USB (4 PIN USB Type A)
- Cables Included
- USB cable
- Included Accessories
- Carrying case
- Limited warranty - 2 years
