Poly Plantronics Calisto 610-M USB Speakerphone (MS Lync)
Quicklinx: B3TVWS00 Mfr#: 201859-02
The Plantronics Calisto 610 is a corded USB speakerphone for plug-and-play conferencing convenience. The Calisto 610 USB speakerphone turns any PC into a portable conferencing device.
Manage calls - anywhere - with plug-and-play convenience. The compact speakerphone integrates with leading softphones to easily manage calls and set up small informal conferences. Single-touch controls include call answer/end, volume adjust, and mute.
Compatibility with a Kensington style lock feature boosts security when deployed in small/medium work areas and shared conference rooms. With crisp wideband audio and full-duplex 360-degree microphone pick up, enjoy business- quality sound for everyone on the call.
Poly Calisto P610-M - speakerphone
Speakerphone - wired - USB
Recommended Use
Computer - communication
Wired
Microphone
Built-in
Controls
Mute, volume, answer/end
Series
600 Series
11 cm
11 cm
3.2 cm
Recommended Use
Audio Output
Wired
Microphone
Directivity Angle
360°
Audio Input Details
Omni-directional - 360°
Remote Control
Controls
Connector Type
USB (4 PIN USB Type A)
Carrying case
Cable Details
USB cable
