Meet the first corded headset designed for unified communications that's as discrete as it is professionally sounding. The headset's modular over-the-ear design can be worn with two ear buds for stereo, or converted to one ear bud for mono use depending on the user's preference. The ultra-discrete design and superior audio quality you've come to expect from Plantronics make this headset ideal for video conferencing, PC telephony and multi-media applications. With the Blackwire 435, you don't have to compromise between style and sound quality.
- Plantronics Blackwire C435 - headset
- Product Type
- Headset - wired
- Recommended Use
- Computer
- Headphones Form Factor
- Convertible
- Connectivity Technology
- Wired
- Sound Output Mode
- Stereo
- Microphone
- Boom
- Controls
- Mute, volume, answer/end
- 1 year warranty
- Product Type
- Headset
- Recommended Use
- Computer
Headphones
- Convertible
- Wired
- Sound Output Mode
- Stereo
- In-Cord Volume Control
Microphone
- Boom
Remote Control
- Controls
- Connector Type
- USB (4 PIN USB Type A)
- Cables Included
- Headset cable
- Limited warranty - 1 year
