Plantronics Blackwire C3210 USB-C Wired Headset
Quicklinx: DY1RWS00 Mfr#: 209748-101
Recommended Use: Computer
Connectivity: Wired
Earcover : Monaural
Stock Status: In Stock, Used Stock
More than 50 in stock
£26.10 ex VAT
£31.32 inc VAT
Standard delivery Delivered within 3-5 working days
The Plantronics Blackwire 3200 series provides corded UC headsets that are durable, comfortable, easy to deploy.
  • Superior audio quality
    Offering PC wideband, a noise-canceling microphone, Blackwire 3200 headsets provide a signature truly outstanding audio experience - ideal for voice, music and multimedia. The dynamic EQ feature optimizes your voice quality when you're on a call and automatically adjusts the EQ settings when you're listening to music or multimedia.
  • Connectivity options
    Ideal for knowledge workers who need a solution for managing calls on their PC, mobile phone or tablet. Blackwire 3200 series offers the comfort and durability of corded combined with flexibility - at an entry-level price point.
  • Comfort and portability
    Enjoy the security of a comfortable fit. A lightweight metal headband offers durability and a custom fit.
Poly Blackwire C3210 USB-C - headset
Headset - wired - USB-C
Compatibility
Mac, Windows
Recommended Use
Computer - communication
Headphones Form Factor
On-ear
Wired
Sound Output Mode
Mono
Audio Specifications
Frequency Response 20 - 20000 Hz
Microphone
Boom
Controls
Mute, volume, answer/end, hold, redial
Series
3200 Series
Compatibility
Mac, Windows
Dimensions & Weight Details
87 g
Recommended Use
Protection
Hearing protection
Headphones
On-ear
Wired
Sound Output Mode
Mono
Frequency Response
20 - 20000 Hz
In-Cord Volume Control
SoundGuard Technology
Microphone
Boom
Headset microphone
Frequency Response
100 - 10000 Hz
Remote Control
Controls
Connector Type
USB (USB Type-C)
USB cable
Used stock
What is used stock?
Accessories Packaging Functional Software Manuals
Ref: DY1R 041531
Condition: Customer return - item has been used and shows signs of use
This part of the stock item is present and in good condition  This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.  This part of the stock item is present and in good condition  This part of the stock item is not applicable e.g. it might not include accessories or software as standard  This part of the stock item is not applicable e.g. it might not include accessories or software as standard  £12.99
Legend
  • This part of the stock item is present and in good conditionThis part of the stock item is present and in good condition
  • This part of the stock item is not present or functionalThis part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standardThis part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.This item has not been tested.
Connectivity: Wired
Earcover : Monaural
Brand: Plantronics
Stock Status: Used Stock
Price Range Ex VAT: 0 - 50
