Product
Plantronics Blackwire C320-M (MS Lync optimised) was 84YF
Quicklinx: CPZLWS00 Mfr#: 85619-101
More headset for your UC dollar. Enter UC with the best-featured headset you never thought your budget could afford. Blackwire 300 series USB headsets are a simple-to-use, comfortable, and durable choice for conference calls, web-based training, and PC multimedia applications. Plus, they're priced right, easy to deploy, and offer a simple-to-upgrade UC solution that IT can roll out easily and rely on.
Plantronics Blackwire C320-M - headset
Headset - wired
Recommended Use
Computer
Headphones Form Factor
On-ear
Wired
Sound Output Mode
Stereo
Audio Specifications
Frequency Response 20 - 20000 Hz
Microphone
Boom
Controls
Mute, volume, answer/end
2 years warranty
Headset
Series
300 Series
Recommended Use
Computer
Headphones
Supraaural
Wired
Sound Output Mode
Stereo
Frequency Response
20 - 20000 Hz
In-Cord Volume Control
Microphone
Boom
Frequency Response
100 - 10000 Hz
Remote Control
Controls
Connector Type
USB (4 PIN USB Type A)
Headset cable
