Plantronics BLACKWIRE 7225,BW7225,USB-C,BLACK,WW
Quicklinx: F80LWS00 Mfr#: 211145-01
Recommended Use: Computer
Connectivity: Wired
More than 50 in stock
£121.95 ex VAT
£146.34 inc VAT
With its boomless corded headset design, hi-fi stereo sound, and all-day comfort, Plantronics Blackwire 7225 helps makes work more productive in open office environments - meeting the needs of office professionals and IT alike.
  • Distraction-free productivity
    Today's workplace environments are usually noisy with frequent interruptions. Blackwire 7225 delivers active noise canceling (ANC), minimizing background noise so that you can tune out distractions and tune into conversations.
  • A corded, boomless design
    Blackwire 7225 features a pioneering boomless headset design, with hi-fi stereo sound and either USB-A or USB-C connectivity. Lightweight and stylish, it's comfortable and delivers Plantronics signature sound and crystal-clear audio - whether you're listening to media or collaborating on voice or video calls.
  • Designed for the way you work
    Blackwire 7225 makes switching from concentration to collaboration on the spot easy. One-touch call and media controls are easily accessible. Dynamic mute alert lets you know if you are talking while muted, which helps make sure your colleagues catch your every word.
Poly Blackwire 7225 - headset
Headset - wired - USB-C
Recommended Use
Computer - voice
Additional Functions
USB DAC, volume limiter, SoundGuard DIGITAL
Headphones Form Factor
On-ear
Wired
Sound Output Mode
Stereo
Sound Effects
Signature Sound, Crystal Clear, dynamic equaliser
Audio Specifications
Frequency Response 20 - 20000 Hz - Sensitivity 127 dB
Impedance
32 Ohm
Active Noise Canceling
Microphone Operation Mode
Omni-directional
Microphones Included
4
Controls
Mute, volume, answer/end, play/pause, next/previous track
Software Certification
Certified for Microsoft Teams
155 g
Headband Material
Leatherette, metal
Earpad Material
Leatherette
Recommended Use
Computer - voice
Audio Output
On-ear
Wired
Sound Output Mode
Stereo
Sound Effects
Frequency Response
20 - 20000 Hz
Sensitivity
127 dB
Impedance
32 Ohm
Diaphragm
32 mm
Adjustable Headband
Volume Limiting Function
Voice alerts
Microphone
Built-in
Omni-directional
4
Sensitivity
-26 dBFS
Frequency Response
100 - 10000 Hz
Remote Control
Controls
Connector Type
USB (USB Type-C)
Carrying case
Cable Details
Headset cable - straight
Connectivity: Wired
Brand: Plantronics
Price Range Ex VAT: 100 - 150
