Smart wireless
Go beyond basics with today’s smartest technology. Streaming audio pauses as soon as you slip off the headphones and resumes playback when you put them on. Control two Bluetooth devices - think smartphone and tablet - up to 330ft/100m away without even touching them.
Connect to what matters
Escape into your playlists and podcasts while you go about your day. With up to 18 hours of streaming and the option to plug in for non-stop listening, there’s no reason for the music to stop. When a call rings in, your music pauses for your conversation.
Class 1 Bluetooth
Control devices from up to 330ft/100m away.
18-hour battery life
Listen wirelessly for up to 18 hours per charge.
Smart sensors
Pause/play streaming audio as you remove/put on headphones.
Multipoint
Connect and control two Bluetooth devices.
All-day comfort
Show your ears some love and slip on the BackBeat SENSE headphones. Pillow-soft, memory-foam cushions and a self-adjusting headband fit you so naturally, they feel made just for you. They’re so light and comfortable that, if it wasn’t for the music, you’d forget they were on.
Welcome to nonstop listening
There are music listeners and there are music lovers. Music listeners use tunes just to pass the time. But as music lovers, you see every song as part of the unique soundtrack of your lives. -
Smart wireless
Go beyond basics with today's smartest technology. Streaming audio pauses as soon as you slip off the headphones and resumes playback when you put them on. Control two Bluetooth devices - think smartphone and tablet - up to 330ft/100m away without even touching them. -
Escape into your playlists and podcasts while you go about your day. With up to 18 hours of streaming and the option to plug in for non-stop listening, there's no reason for the music to stop. When a call rings in, your music pauses for your conversation. -
Class 1 Bluetooth
Control devices from up to 330ft/100m away. -
Listen wirelessly for up to 18 hours per charge. -
Smart sensors
Pause/play streaming audio as you remove/put on headphones. -
Multipoint
Connect and control two Bluetooth devices. -
All-day comfort
Show your ears some love and slip on the BackBeat SENSE headphones. Pillow-soft, memory-foam cushions and a self-adjusting headband fit you so naturally, they feel made just for you. They're so light and comfortable that, if it wasn't for the music, you'd forget they were on.
