Poly Plantronics Backbeat Pro 2 Wireless Headset Graphite Grey Special Editio
Quicklinx: DFHTWS00 Mfr#: 207120-05
BackBeat Pro 2 wireless headphones shape the sounds of your day with on-demand active noise canceling, wireless freedom, and immersive audio.
  • From sound to silence and back
    On-demand active noise canceling creates an oasis of personal space in a public place with one touch. To hear announcements and conversations around you, simply activate open-listening mode. When you remove your headphones, smart sensors pause your music automatically, then resume when you put them back on.
  • Immerse in exceptional audio
    From music to movies, BackBeat Pro 2 pulls you in with the richness and definition of Plantronics signature audio quality. High notes sound crisp, mid-tones sound natural, and deep powerful bass delivers low notes with minimum distortion.
  • Go farther with true wireless freedom
    Enjoy enough listening time to take you through your long working days or redeye flights with several hours of music, movies, and calls on a single charge. Plus, you can connect to two devices at once and easily switch as needed from concentration to conversation.
Poly - Plantronics Backbeat Pro 2 - headphones with mic
Headphones - Bluetooth - wireless
Recommended Use
Portable electronics
Headphones Form Factor
On-ear
Wireless
Wireless Technology
Bluetooth
Bluetooth Version
Bluetooth 4.0 EDR
Sound Output Mode
Stereo
Audio Specifications
Frequency Response 20 - 20000 Hz - Sensitivity 93 dB
Impedance
32 Ohm
Active Noise Canceling
Controls
Volume, answer/end, play/pause, next/previous track
289 g
Recommended Use
Max Operating Distance
100 m
Audio Output
On-ear
Wireless
Wireless Technology
Bluetooth
Bluetooth Version
Bluetooth 4.0 EDR
Bluetooth Profiles
Hands-Free Profile (HFP), Headset Profile (HSP), Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP)
Sound Output Mode
Stereo
Frequency Response
20 - 20000 Hz
Sensitivity
93 dB
Impedance
32 Ohm
Diaphragm
40 mm
Microphone
Built-in
Remote Control
Controls
Wireless Link
Transmission Range
100 m
Connector Type
Headphones (mini-phone stereo 3.5 mm 4-pole)
Travel pouch
Cable Details
USB charge cable , Headphones cable
Headphone battery rechargeable - Lithium Ion
Run Time (Up To)
24 hour(s)
Recharge Time
3 hours
