Plantronics BackBeat FIT Wireless Bluetooth Headset - Lime Green
PERFECT FOR THE BUSY PROFESSIONAL - STREAM MUSIC & NEVER MISS A CALL!
Quicklinx: 9F9PWS00 Mfr#: 200460-05
It's time to get moving and get Fit. Whatever your workout, the flexible, sweat-proof Plantronics BackBeat Fit wireless stereo headphones keep pace with you. Its powerful audio lets you clearly hear your music while its safety-oriented design lets you hear your surroundings and be seen at night. The reversible armband secures your smartphone while you're moving and stores your headphones when you're done - making it your perfect workout partner.
Poly - Plantronics Backbeat FIT - earphones with mic
Earphones - Bluetooth - wireless
Recommended Use
Portable electronics
Lime burst
Headphones Form Factor
Ear-bud - behind-the-neck mount - binaural
Wireless
Wireless Technology
Bluetooth
Bluetooth Version
Bluetooth 3.0
Sound Output Mode
Stereo
Audio Specifications
Frequency Response 50 - 20000 Hz - Sensitivity 105 dB/mW
Microphone
Built-in
Controls
Answer/end, play/pause, next/previous track
1-year warranty
24 g
Lime burst
Recommended Use
Max Operating Distance
10 m
Audio Output
Wireless
Wireless Technology
Bluetooth
Bluetooth Version
Bluetooth 3.0
Bluetooth Profiles
Hands-Free Profile (HFP), Headset Profile (HSP), Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP)
Sound Output Mode
Stereo
Frequency Response
50 - 20000 Hz
Total Harmonic Distortion (THD)
3%
Sensitivity
105 dB/mW
Diaphragm
13 mm
Magnet Material
Neodymium
Microphone
Built-in
Remote Control
Controls
Wireless Link
Transmission Range
10 m
Connector Type
USB
Cable Details
Micro-USB cable
IP54
Headphone battery rechargeable - lithium polymer
Run Time (Up To)
8 hour(s)
Standby Time
336 hours
Limited warranty - 1 year
