It's time to get moving and get Fit. Whatever your workout, the flexible, sweat-proof Plantronics BackBeat Fit wireless stereo headphones keep pace with you. Its powerful audio lets you clearly hear your music while its safety-oriented design lets you hear your surroundings and be seen at night. The reversible armband secures your smartphone while you're moving and stores your headphones when you're done - making it your perfect workout partner.
- Plantronics Backbeat Fit - earphones with mic
- Product Type
- Earphones - Bluetooth - wireless
- Recommended Use
- Portable electronics
- Electric blue
- Headphones Form Factor
- Ear-bud - behind-the-neck mount
- Connectivity Technology
- Wireless
- Wireless Technology
- Bluetooth
- Bluetooth Version
- Bluetooth 3.0
- Sound Output Mode
- Stereo
- Audio Specifications
- Frequency Response 50 - 20000 Hz - Sensitivity 105 dB/mW
- Microphone
- Built-in
- Controls
- Answer/end, play/pause, next/previous track
- 1 year warranty
- Product Type
- 24 g
- Electric blue
- Recommended Use
- Max Operating Distance
- 10 m
Headphones
- Wireless
- Bluetooth
- Bluetooth Version
- Bluetooth 3.0
- Bluetooth Profiles
- Hands-Free Profile (HFP), Headset Profile (HSP), Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP)
- Sound Output Mode
- Stereo
- 50 - 20000 Hz
- Total Harmonic Distortion (THD)
- 3%
- Sensitivity
- 105 dB/mW
- Diaphragm
- 13 mm
- Magnet Material
- Neodymium
Microphone
- Form Factor
- Built-in
Remote Control
- Controls
Wireless Link
- Transmission Range
- 10 m
- Connector Type
- USB
- Cables Included
- Micro-USB cable
- IP54
- Battery
- Headphone battery rechargeable - lithium polymer
- Run Time (Up To)
- 8 hour(s)
- Standby Time
- 336 hours
- Limited warranty - 1 year
